Brake bleeding
DOT/NHTSARIN: 2127-AK58Publication ID: Fall 2009
Title: ●FMVSS 116, Motor Vehicle Brake Fluids, EPDM Rubber
Abstract: This rulemaking would amend FMVSS No. 116, Motor vehicle brake fluids, so that brake fluids would be tested with ethylene propylene diene terpolymer (EPDM) rubber, as this type of rubber is increasingly used in brake fluid seals. This rulemaking would also update references to voluntary standards issued by the SAE International and the American Society for Testing and Materials.
Agency: Department of Transportation(DOT)
DOT/NHTSARIN: 2127-AK58Publication ID: Fall 2018
Title: FMVSS 116, Upgrade Rubber for Brake Fluid Testing
Abstract:
NHTSA withdraws its notice of proposed rulemaking (NPRM), published on February 3, 2010, proposing amendments to the Federal motor vehicle safety standard (FMVSS) No. 116, Motor vehicle brake fluids. Since publication of the NPRM and after review of the comments, the agency has determined that updates and corrections outside the scope of the notice are necessary in order to publish a final rule. Based on this, the agency has decided to withdraw the proposal to amend FMVSS No. 116.
