[C2] Stripped Spark Plug Hole
Old Mar 8, 2019 | 07:26 PM
halvernaz's Avatar
halvernaz
Default Stripped Spark Plug Hole
I have a 66 with a 327/350 hp and my number one spark plug hole is stripped.
Was looking for what size tap I could use to clean up the threads.
Any other ideas/suggestions would be greatly appreciated.
Henry
Old Mar 8, 2019 | 07:36 PM
856666's Avatar
856666
Hi Hal
Welcome to the forum
If cross threaded there are thread chasers available at parts stores or on line
If stripped then a Helicoil is your best bet.
Phil
Old Mar 8, 2019 | 07:41 PM
survivor66's Avatar
survivor66
Hope the engine is out so you can work on it upside down. Gravity is your enemy here.
GUSTO14's Avatar
GUSTO14
My suggestion would be to go with a Heli-Coil® Spark Plug Screw Thread Insert
Designed and manufactured by Heli-Coil to provide specific and unique benefits to high-temperature, high-performance spark plug applications.
Heli-Coil spark plug screw thread inserts are manufactured from 18-8 round stainless steel wire formed into a 60° diamond-shaped wire. This cold-worked wire, which has a tensile strength of 200,000 PSI, is wound into a helical coil with a driving tang and notch to remove the tang after the insert is screwed into the Heli-Coil tapped hole.
In its free state, the insert is larger in diameter than the tapped hole. Once installed, the insert assumes the configuration of the tapped hole. The resulting outward spring-like action anchors the insert in place. The Heli-Coil spark plug insert becomes an integral part of the cylinder head, providing high-strength threads which exceed in surface smoothness, hardness, and accuracy any threads tapped in any material.
Good luck... GUSTO
Old Mar 8, 2019 | 07:42 PM
Factoid's Avatar
Factoid
Summit sells a whole array of repair kits at a variety of prices. Don’t cheap out. The cheap ones will barely work on aluminum heads.
https://www.summitracing.com/search/...0Insert%20Kits
Use chassis grease in the threads to catch the filings and keep them out of your engine, then put your shop vac over the hole to suck out any remaining chips.
Robert61's Avatar
Robert61
Get a Helicoil kit. They're cheap most auto parts stores have them. You don't drill just screw the tap in. Pack the flutes with grease so metal chips will not go into the cylinder as best you can. Then install the short Helicoil. After it's installed remove the tang with a pair of needle nose pliers. Then you are good to go. Don't get scared by the horror stories of what might happen. On the 2007 Ford and other years the spark plugs break off in the head. The repair is to beat the center of the spark plug into the cylinder and drill the plug body out. Then you are supposed to blow all of the debris out the exhaust.
WOW, when I started typing there were no comments.
Old Mar 8, 2019 | 07:48 PM
sidepipe seeker's Avatar
sidepipe seeker
Do NOT use a "tap"!!!!....You NEED to use a "Thread Chaser".....size is 14 x1.25mm....
https://www.northerntool.com/shop/to...hoCQ3kQAvD_BwE
Make SURE that the cylinder that is being "thread chased"...has the PISTON in the highest position in the cylinder...this will make SURE that any particles from the thread chasing are at the Highest point ( easiest to vacuum out)...VS.... the piston at the bottom of the stroke...
......Mark
Old Mar 8, 2019 | 07:56 PM
Robert61's Avatar
Robert61
......Mark
How do you chase stripped threads?
Old Mar 8, 2019 | 08:11 PM
sidepipe seeker
Prior to resorting to "heli-coiling"...I personally would make every attempt to restore/use the original spark plug threads....the thread chaser/s are machined such that ...they will chase into maligned/stripped threads...
I Strongly Suggest to everyone that after removing spark plugs...ALWAYS thread chase the spark plug threads...cross threading/ stripping spark plug hole threads is most commonly a result of dirty threads...
The time tested adage of...."An ounce of prevention is worth a pound of cure"...is directly applicable!!.
Also USE a torque wrench and torque to factory torque specs....Guessing is NOT your friend!...Mark
Old Mar 8, 2019 | 08:59 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
They make thread taps that pull the chips out towards you
Old Mar 8, 2019 | 09:02 PM
dcamick's Avatar
dcamick
2019 C1 of Year Finalist (appearance mods)
I'm not involved..........Lots of great comments!!!!
Old Mar 8, 2019 | 11:33 PM
roadster65's Avatar
roadster65
- sounds like to might be "screwed" … … sorry; bad pun.
Old Mar 9, 2019 | 07:51 AM
DansYellow66's Avatar
DansYellow66
......Mark
This. Surely the threads are just crossed up (unless aftermarket aluminum). Carefully try starting a thread chaser and see if that doesn't clean them up before going the helicoil route.
Old Mar 9, 2019 | 08:14 AM
ejboyd5's Avatar
ejboyd5
Chase before committing to Helicoil. Raise piston to top, put a small oiled rag in the cylinder before chasing. Any chips will stick to the cloth and will come out when the rag is removed by grabbing it with a pair of tweezers.
Old Mar 9, 2019 | 11:12 AM
Frankie the Fink's Avatar
Frankie the Fink
Army
I’ve had to helicoil more than one motorcycle spark plug hole. Do that and it will be fine.
Old Mar 9, 2019 | 01:27 PM
GTOguy's Avatar
GTOguy
......Mark
This^^^^^. When I was tuning cars for a living in the 80's and '90's, thread chasers saved the day many a time. The OP has IRON HEADS going by his engine description....have rarely seen a thread chaser fail with an iron head,as the issue is usually only one damaged thread, not an entire 'strip out', as we've seen with aluminum. So, follow Seeker's advice for the cheapest, least invasive, and easiest solution.
To Stripped Spark Plug Hole
