Headlight Voltage
Old Apr 2, 2019 | 05:18 PM
billbonn's Avatar
billbonn
Default Headlight Voltage
65 Coupe, 327/300
I just tested voltage on my headlights with engine running and brights on. I'm seeing 12.3 volts at idle at 12.5 at 2500rpm. I am considering relays but do the experts here think it would add much brightness? If so, should I buy plug and play relay harness or just relays and wiring and splice into the headlight harness in the engine bay before the split? Any feedback would be appreciated. Thanks.
Bill B.
Old Apr 2, 2019 | 05:20 PM
Frankie the Fink's Avatar
Frankie the Fink
Army
Read this article and decide for yourself:
http://www.madelectrical.com/electri...adlights.shtml
Old Apr 2, 2019 | 05:26 PM
billbonn's Avatar
billbonn
I have read that article, Frankie and just reread it before posting my question here. I am thinking relays would help some but not sure how much and that is why I posed the question here. I have read numerous post you have posted on this subject and I value the opinions of folks like you since my electrical experience isn't that vast.
Old Apr 2, 2019 | 05:35 PM
Frankie the Fink
Army
If you read the article IIRC it states that just a small drop in voltage will reduce headlight brightness by double digits percentage.
Relays will help and the lights will not be too bright....I had relays in my 61...
Old Apr 2, 2019 | 05:37 PM
65GGvert's Avatar
65GGvert
What voltage are you reading at the battery with car running?
Old Apr 2, 2019 | 05:43 PM
billbonn's Avatar
billbonn
14.2 volts at idle.
Old Apr 2, 2019 | 06:05 PM
65GGvert's Avatar
65GGvert
Sounds good
To Headlight Voltage
