Hey Guys need some help. I have a 1966 Corvette problem is a few days after bleeding the system I get a soft pedal. I have bled the car 3 times, not losing any fluid. I can't figure out how air is getting into the system. Any help would be most appreciated. Thanks.
If you are getting a soft pedal after you drive the car, check your rotors with a dial indicator. They may have excessive run out. I aim for under .003. A solution to your problem if the run out is excessive, you could install O-ring pistons. They are more forgiving. Jerry
One possibility is through the rear seal of the master cylinder. Get under the dash and check the carpet, and the actuating rod where it comes through the firewall for signs of brake fluid.
