I'm using an aluminum RAM flywheel in my BB 66 car and like it fine. I believe from memory it's around 18 lbs so it's not one of the ultra-light units. To be honest in the amount of driving I've done since I installed it I haven't noticed a lot of difference from the 30 lb Hays I took out of it.
I've had a couple of them. Used them on 327 and 302. For my driving, they didn't enhance anything except quick revving of the engine. I just put another one in an engine I haven't run yet. Just because........................
The largest problem is to high rear gear ratio or not a broad flat torque curve causing the car to bough down. Heavy car can be a problem also. The heavier flywheel “stores” energy in the form of inertia and drives the car at lower rpms. Another important consideration again IMHO is this makes a scatter shield mandatory. Especially in a glass car. Missed shift at higher rpms could be a very unpleasant experience. Just my .02
The 15 lb, 153 tooth factory Chevy ZL1/L88 cast iron FW worked quite well in my L79 '61 Corvette,and also works almost as well in my 427 SB.
I say almost as well because the 427 has less rotating mass in the crank and rods than the L79 did, so the 427 would be happier with perhaps an 18-20 lb FW starting out from a stop, on a hill, especially with some bozo in his automatic car stopped 3 feet behind you. Its not an issue on flat ground. It was not an issue with the L79. It may be cam and big head port volume related, partially.
If your BB car has a normal GM crank and steel rods, the 15 LB FW will be fine,and easy to drive with any rear end/1st gear combo of 9:1 or higher (higher meaning like 10:1).
If you are looking at a real light weight FW of 14 lb or less, I can give no input. A larger dia 168 tooth FW of same weight as a 153 tooth FW will have different characteristics.
flywheel weight was how I tuned our dirt track cars. light wheel when the track was tackey and good traction and a heavy wheel when the track was dry slick and slippery. . the 65 396 corvette had the 15# light nodular iron GM flywheel from the factory
Rex, have used a 10 pound aluminum flywheel on my 69 with a 502. Would want it any other way. Love the way the light wheel drives. Our cars are light enough that they work great. 3.70 gears with an M21. Using it on my new combo as well. Richmond 4+1 with 3.08 gears.
Thanks everyone for your input. It's most informative and I appreciate everyone's comments. Since I have a mint L-88 nodular flywheel (16.8 lbs) I will probably use it.
Rex. I am using a 17lb L88 flywheel in my 65 SB. 355 ci with Richmond non-od 5 speed. I like the way the eng revs up so easily. Fun to drive. One thing though no one has mentioned. The rpms also drop much quicker than with a stock 30lb flywheel between shifts. It changes the way the car cruises and decelerates with clutch engaged. Not a bad thing but different. I got used to it pretty quickly and still prefer it over a stock weight flywheel.
One additional consideration (a bonus?) is that a lighter flywheel will enhance the effect/sound of a lumpy idle. Less rotational mass and resultant inertia does less smoothing out of exhaust pulses at idle speed.
I like that that and the quicker revving!
We tend to think of a Chevy 30 lb flywheel as a heavy weight but I believe many Fords used flywheels as heavy as 40 lbs and I've heard of 47 lbs but haven't been able to verify that one.
drag racers use heavy flywheels because they leave the line at max RPMs
That was a quite old school approach to stick car drag racing that doesn't apply to today except for really odd combinations.
I use a 9 lb aluminum flywheel with a steel heat shield in my Nova.
I use a 15 lb Ram aluminum flywheel in the 66 Corvette behind a 496 BBC, Autogear M22 2.56 1st gear, 3.73 gear car. In this car the 496 has quite a lot of TQ and good gearing the stored energy of a heavy flywheel is simply not needed. Unless you have a short crank 283, 327, 350 with no power I'd almost always go with an aluminum flywheel. But then again I don't build mild hp engines for my cars.
