Flywheel question
Old Jun 3, 2019 | 05:26 PM
GTOguy's Avatar
GTOguy
Originally Posted by DansYellow66
We tend to think of a Chevy 30 lb flywheel as a heavy weight but I believe many Fords used flywheels as heavy as 40 lbs and I've heard of 47 lbs but haven't been able to verify that one.
A bit off topic here, but my old 1915 Ford had a 90 pound flywheel/magneto/transmission assembly spinning on the back of it's spindly (but forged vanadium steel) crankshaft. A big reason why it could move out from a stop at 250-400 rpm without stalling, and operate in high gear from about 8 mph to 45 mph without chugging or lurching. With 20 horsepower, flywheel inertia is king. With a high winding Chevy engine with a stout rear gear, not as much need for it. All depends on the type of driving and the preference of the driver.
Old Jun 3, 2019 | 05:47 PM
MikeM's Avatar
MikeM
A hit-and-miss engine is a type of flywheel engine. Aflywheel engine is an engine that has a large flywheel or set of flywheels connected to the crankshaft. The flywheelsmaintain engine speed during engine cycles that do not produce driving mechanical forces.
Old Jun 3, 2019 | 06:52 PM
PAmotorman's Avatar
PAmotorman
things have changed because when I was building tunnel ram roller cam BBC for drag only camaros we used 5:13 rear gears and 40# flywheels to go high 9s and low 10s
Old Jun 3, 2019 | 06:55 PM
AZDoug's Avatar
AZDoug
C1 of Year Finalist (performance mods) 2019
2017 C1 of Year Finalist
What works for 1/4 mile cars, turns a street car into a pig. Unless you launch at 8K RPM with drag slicks at every stop light...
Doug
Old Jun 3, 2019 | 09:15 PM
PAmotorman's Avatar
PAmotorman
Doug
when I was street racing for $$$ to make car payments I ran some 4:88 in my street car.
Old Jun 3, 2019 | 09:23 PM
PAmotorman's Avatar
PAmotorman
a friend has a very big hit and miss engine with 6 foot flywheels that you walk up the spokes to get it started. it was used in a west va.. coal mine owned by his father in law to pump water out of the mine.
Old Jun 4, 2019 | 07:15 AM
MikeM's Avatar
MikeM
Wonder if the engine ever kicked back while the spoke walker was doing his thing and flipped him like a ping pong ball?
