I've started working on a 63 and noticed the engine isn't centerline. It's offset about 3/4 inch to the passenger side. I've searched and found pictures of other C2s and they appear to be offset too.
Is this as designed and if so why are the engines offset?
By design.
My guess. More foot room for pedals and the driver's feet. Better alignment, engine center line to the pinion shaft.
My thinking is it all starts out with the rear end which with equal length half-shafts results in the pinion being offset to the right by the ring gear. After that the driver foot box room, weight distribution, steering box room, gear shifter placement, etc are all benefits.
That is, until that same American car is built as an export, right hand drive model. The engine is in the same place as left hand drive.
By design..Better alignment, engine center line to the pinion shaft..
Many cars (and trucks especially) exhibit this lack of driveline symmetry. The explanation I've always had was pinion shaft angle and associated alignment issues.
Tadge touched on this a while back in an "Ask Tadge". He stated that they offset the drive-line to help with the weight balance once a driver was in the vehicle. He was referring to a C4 if I remember correctly so it may not be for the same reason, but I wouldn't be surprised.
MikeM's comment not withstanding, I had the understanding that its because of the steering column and box location. Also, I have found that the steering wheel position is a little "canted" to the left hand of the driver (closer to driver at 10 oclock and further at 2)....not sure they're all that way.
I am sure there's an engineer type on the forum who can explain this....
I believe all/most of the rear wheel drive Chevrolet line up of cars (Chevy II, Chevelle, Impala, Corvette, except Corvair of the '60's and '70's had the engine offset to the right. Some where the steering box was nowhere close to the engine.
At least some Pontiacs, Olds and Buicks were the same way. I'm thinking Chevy pickup trucks were the same way.
Is it true that Europeans have small feet?
It was a side benefit if I wasn't clear enough. RH drive exports were probably pretty small in numbers. Not all Europeans drive on the left side of the road. .
Funny, I typed "Google"....got a return of "Google"....typed pinion offset, got your referenced article...interesting (relatively speaking)..."its all good"...as "they" say.
Only the britisch do, and I don't think the C2 was ever available in RHD
That's pretty much what I was thinking too, Alexander. I know the Australians have converted some Vettes to RHD but I don't ever remember seeing a factory one. Maybe JohnZ or someone can verify.
SAE paper 630064 that chronicles the design and development of the 1963 Corvette states that the engine was offset one inch to the right of vehicle centerline in order to provide more room in the driver's footwell.
