[C1] T5 conversion thread?
Old Jun 24, 2019 | 01:57 PM
John S 1961's Avatar
John S 1961
Default T5 conversion thread?
Having trouble finding a good c1 t5 conversion thread. Anyone have one.
Old Jun 24, 2019 | 06:59 PM
John S 1961
Help!
Old Jun 24, 2019 | 09:47 PM
Geralds57's Avatar
Geralds57
2024 C1 of the Year Winner - Modified
2023 C1 of the Year Finalist - Modified
2022 C1 of the Year Finalist - Modified
2020 C1 of the Year Finalist - Modified
2019 C1 of Year Finalist (performance mods)
2018 C1 of Year Finalist
What type of info are you looking for?
Old Jun 25, 2019 | 07:46 AM
CaptainEgg's Avatar
CaptainEgg
Almost Retired
Are you wanting info on buying a complete kit or just the t5 and piecing it together?
Old Jun 25, 2019 | 12:16 PM
John S 1961
Piecing together. Picking up the 83 camaro bellhousing today. Need all tips and tricks and parts picks. Want to do my low hp c1 economically.
Old Jun 25, 2019 | 12:23 PM
Tom Austin's Avatar
Tom Austin
John,
I have installed a T5 in my 66 and wrote an extended thread about my installation - did you see it by chance? Lots of info in there including how to modify a c2 transmission mount to make it work - that may work for you as well. Hope this helps!
Tom
Old Jun 25, 2019 | 04:36 PM
GTOguy's Avatar
GTOguy
You have already completed the toughest part of the job.....finding that canted '83 Camaro bell housing! From what I hear, that part is key to the installation.
Old Jun 26, 2019 | 05:56 AM
Hermn59's Avatar
Hermn59
Originally Posted by Tom Austin
John,
Tom
https://www.corvetteforum.com/forums...tall-done.html
https://www.corvetteforum.com/forums...my-66-a-2.html
Old Jun 29, 2019 | 01:06 PM
Fngrs's Avatar
Fngrs
2nd Gear
I have a 59 with a T5 installed. Poor job but it will bolt to the cast bellhousing and you need to mod the mount if you use the 17 degree T5 out of 83 vintage Camaro firebird ( non World Class ). If you are pushing power get the World Class trans. The floor needs to be cut and the ashtray pocket will be compromised.
Old Jun 30, 2019 | 10:33 AM
ryan22's Avatar
ryan22
A post I read on this topic suggested using a Ford T5 tailshaft. This moves the shifter location forward. I’ve read posts from some who’ve done this & not had to cut their tunnel.
Old Jun 30, 2019 | 11:20 AM
65YellowJacket's Avatar
65YellowJacket
Not a C1 but I just removed a T5 swap from my C2 because I'm upgrading the engine to a LS3. Looks to be a pretty simple swap. Previous owner used stock rear mount and welded it to the cross member at an angle. They also kept the stock mechanical linkage for the clutch. I think if I was doing the swap, I would have mounted the rear mount to a piece of angle iron and made it bolt in. I think you'll be happy with the swap unless you are running a high horsepower engine. Shifts much better than a TKO or T56 IMHO. Trans is also much lighter and smaller. Plenty of room in the tunnel. Let me know if you need any part numbers of the bell housing etc. As soon as I get home to take some pictures, I'll be posting the complete swap (bell housing, transmission, Hurst shifter, transmission yoke) in the for sale section. shameless plug :-)
Old Jun 30, 2019 | 12:58 PM
John S 1961
So just the ashtray pocket needs pocket gets removed? I can live with that.
Old Jun 30, 2019 | 01:13 PM
John S 1961
Thanks and let me know. Shipping will probably be a pain.
To T5 conversion thread?
