62 upper Windshield frame
Old Jul 30, 2019 | 11:42 AM
Butts's Avatar
Butts
1st Gear
Default 62 upper Windshield frame
Having trouble installing the upper windshield frame with upper molding. Can't get the frame into the tabs on either side correctly! Is there a trick to installing this?
Old Jul 30, 2019 | 12:24 PM
FX VETTE's Avatar
FX VETTE
Try posting this in the C1 & C2 General area of the forum. You posted this in the intro section.
Old Jul 30, 2019 | 02:58 PM
mike coletta's Avatar
mike coletta
Not sure what you're talking about. The ST 12 has pretty good info on the assembly of the windshield frame. There is also a ton of information on this forum (search function). If you're talking about the header stainless, you sit it on top of the completed assembly, and hit it with the palm of your hand. It snaps right on. You have to separate the stainless from the steel "u" channel in order to assemble the frame. If you're trying to assemble the frame, with those two pieces still together, it ain't gonna happen.
Old Jul 30, 2019 | 03:03 PM
mike coletta
Here, I did it for you https://www.corvetteforum.com/forums...-tutorial.html
To 62 upper Windshield frame
