adjusting valve lash
Old Oct 17, 2019 | 07:03 AM
MikeM's Avatar
MikeM
Originally Posted by Powershift
This is the way it should be done.........hot and running.
Doing it cold with engine down is acceptable for initial startup and if you really know what you are doing. Then follow-up with "hot and running "after engine start.
Larry
Makes one wonder how the engine plant did it when the engine was built doesn't it?
My bet is the engine plant adjusted the valves as part of the initial assembly before the engine was altogether. Solid and hydraulic lifters both.
That said, I've always done it the way you described.
Old Oct 17, 2019 | 05:27 PM
GTOguy's Avatar
GTOguy
My feelings as well. I've always done it during assembly prior to initial fire up and then 'double checked it' warm and running to make sure.
When I assembled my '61's engine a month ago, I did exactly that. The 'hot and running' check I did after fire -up verified that I got them right during assembly, so I simply re-installed the valve covers and moved on. I'm always more comfortable when I KNOW none of the valves are too tight.
