[C1] Possible 700-R4 install
I was thinking this cooler may be sufficient for trans fluid cooling for a 700.
https://www.summitracing.com/parts/f...0618/overview/
I would plan on putting it horizontally, below the front of the radiator, where the removable fiberglass baffle is that sits above the the front license plate brackets. I would think it would get good air flow there, either air up from the road into the area behind the grill, or air down, in that position.
I suppose I could hook up a simple in-car U tube water manometer to the area in front of the radiator and go driving and see if the pressure is positive, or negative.
For those that have 700 auto trans, where and what did you use for trans cooling? I don't want to put any extra heat load on the radiator by placing the cooler in front of it.
Thanks,
Doug
Thanks,
Doug
Doug I installed a Bowtie overdrive 700 R4 four years ago in my wives 62 with a 340 HP. Installed a Dewitts radiator with a cooler and electric fans. The Overdrive in the 700 R4 greatly reduces the heat when the OD is used. I have no other cooler and the trans temp stays in the 150 to 160 range in the summer. I change the fluid almost every year and it is still nice and red with no burnt smell. A cooler is nice but don't know if it is required in this transmission. In Arizona it might be a good idea but here in Oregon it is not required. Hope this helps and good luck.
Billy
Billy
Received 5,608 Likes
Doug, I mounted the cooler for the 700R4 in my ‘61 under the trunk with a thermostatically controlled fan.
Not a 700 R4, but I mounted the trans cooler for my 4L80E on the passenger side frame rail. The fans are some from the computer world purchased off ebay. I did not want the cooler in front of the radiator and as close to the trans as possible. Here is a picture taken when under construction.
Received 3,443 Likes
Billy
Billy
I already have a fairly expensive DeWitts aluminum resto radiator with NO trans cooling lines. I never paid any attention to whether PG equipped C1s have rads with trans cooler fittings.
I don't really want to replace it, thus my search for another cooler.
Factoid: where did you install and what did you use for a temp control switch?
I read that 150-170F is about optimum for trans fluid.
Thanks,
Doug
Thanks,
Doug
That looks like a fairly simple install. Is that a small spin on fluid filter I see? The cooler doesn't look very large, maybe it doesn't need to be.
I would be temped to put a very heavy 1/4" mesh screen over the bottom of the cooler, in that location,
As per an engine oil cooler i installed in a splash pan years ago.
Doug
Attachment 48346192
Attachment 48346193
Doug
Attachment 48346192
Attachment 48346193
Doug, in your link to Summit you will see on the right side a cooler sold by B&M. I believe they are made by DeRale, this type cooler is the same unit used by GM in a lot of the 1/2 ton trucks, 2 and 4 wd in the 2000 year ranges. They are availble in 3 or 4 sizes.
I like them because they are compact but do a great job cooling. The build design is similar to a modern aluminum radiator so more cooling per inch. I ran one in a 2001 Denali, 6.0L 4L65HD after I had a tranny failure. Ran it direct without the radiator but mounted it in front of the radiator. In Northern California with temp rages from 30 in winter to 105 in Summer it kept the tranny cool always and I towed with that vehicle. In a Corvette with very low weight I see no reason for a cooling fan if the cooler is large enough and exposed to some airflow.
Doug
Doug
Charles
