Question about engine install
Old Dec 22, 2019 | 09:42 PM
99Silverbullet's Avatar
99Silverbullet
CI 8 & 9 Veteran
C2 of Year Finalist (performance mods) 2019
St. Jude Donor '07-'08
Originally Posted by Avispa
I've R&R'd my big block several times with the fuel pump attached. You shouldn't have any trouble doing the same on a small block. The installation is a lot easier with the bellhousing attached to the transmission, and the clutch already installed on the flywheel. Plan to use a good steel alignment tool on the clutch to do the latter. The plastic things that come with clutch kits are dicey and may make it very hard to slide the trans shaft through the clutch disk. It should slide right in, no forcing needed.
Second this, did it this way twice with my bb during restoration. Dont ask
Old Dec 22, 2019 | 09:44 PM
ed,s64's Avatar
ed,s64
Well here it is 2 days before christmas and waiting for my last part.Putting in a new accelerator pedal swivel rod the were good to get her back together. Everyone enjoy your holidays. Elio
