[C2] Bubba was here
Old Dec 10, 2019 | 11:01 AM
I'll C2 it's Avatar
I'll C2 it
Originally Posted by 67L88Vette
So it is likely recracking then, and I wouldn't use that part ... I'd also check to make sure the the trailing arm side of this flanges mating surface is flat, as it could be the part is cracking from being drawn down on a bent surface ... Something caused the part to fail in the first place, and now it looks like it's doing the same to the weld ... If not corrected, you may have the same failure again with another part ...
John A, 67L88Vette
Thanks for the tip, all parts will be inspected and replaced as needed during reassembly.
Old Dec 10, 2019 | 11:12 AM
1snake's Avatar
1snake
Originally Posted by MikeM
Since it cracked again, I'd replace it. I'll stick with my theory that flange was bent/broken trying to get a Ujoint in/out. .
That's exactly why it cracked. Unless the flange is bolted to the correct fixture, it's almost impossible to install or remove the u-joint without bending it. Most Corvette supply houses have the correct tool.
To the O.P., throw that flange in the trash, new ones are less than $50.
Old Dec 10, 2019 | 11:19 AM
John S 1961's Avatar
John S 1961
Originally Posted by GTOguy
Not really Bubba, IMO. More of a workman-like repair done when the car was only a decade old or so. I agree that it should be good to go for the next 40 years. The only crime committed here is ugliness.....he didn't grind the weld down so it looked better. Looks to be plenty strong, and if the last 40 years are any evidence, it is.
good welding in a structural application should NOT be ground
Old Dec 10, 2019 | 11:59 AM
itsforfun's Avatar
itsforfun
[QUOTE=Jackfit;1600625810]We had to get to work the next day or the next hour and these cars always broke...50 years ago...bad gas, plugged filters, stuck in gear, water pumps leaking , u joints going...but we still had to get to work...they were our daily drivers....and we were not great mechanics back then as we are now...
Jack
Bubba might have had a HOT date!
