Can anyone tell me whether or not you have to glue in the windshield on a 54 Corvette. The upper molding deems to work it's way up off the glass. Original molding and original glass. Seems to fit well with new rubber but you can tell it works its way up in the center. I've only set silicone in the bottom molding track .
Couple thing
Typically the AM glass is too small - cut short at the top
Also glue it in
also do not latch the conv top latch super tight - it will pull the frame off the glass
when your not using the the car - leave the latches un latched
I think the problem is the aftermarket glass. The doorpost tabs are intact so I guess I'll have to glue it in. Thanks for all the helpful responses. I appreciate it very much.
