I searched the forum but could not come up with an answer. When the star wheel brake adjuster is installed there is interference with the tension spring. See photo.
The adjuster and spring are installed correctly. The spring stops the adjustment wheel from turning after adjustment. It also provides the distinct click when the star wheel is turned. I like to put a dab of wheel bearing grease on the star wheel/spring contact area, after cleaning of course.
