I only run low beam LEDs, I hardly ever have high beams on.
Buy 'em, unbox 'em and plug them in and go...
They cost more than some of the cobbled together solutions using motorcycle LEDs but they have a better dispersion pattern and don't blind oncoming drivers...
You don't realize how dim non-LED lights are until you compare - here are my hi beams (incandescent) vs my lo beams (LEDS):
Note the upper half of the LED bulbs vs the lower half; this is the design that creates good dispersion. The beam is cut off at a certain height to keep it out of oncoming drivers' eyes.
Frankie, just curious if you're using relays in the headlight wiring with LED headlights. They draw 1/2 of what sealed beam halogens do, so it seems they'd work ok without relays. Time to replace my engine/lighting harness and would like to figure out whether to wire the relays into a new harness.
Mine are shown above without relays but with a fairly new engine bay and lighting harness...
I'm running with that company's older design VCm35 units which have internal fans...
Their newer product, VCm3000 is more sophisticated and doesn't require the fans...
If you read the narrative 1/2 way down the web page whose link I provided above you'll understand more.
I bought a set of four which included the glass lenses, LED fan cooled bulbs and rubber grommets. <$70 on e-bay. Plug and play, they work fine. No Modification required.
Hi guys! Please see post #4 made my me from last September. I used Hella H4 housings and LED bulbs from Headlight Revolution. You will need to re-aim the headlights after installation but using this combination required no modification to the headlight buckets, just plug and play! All links are in the post
