[C1] Convertable top problem
Old Feb 20, 2020 | 06:21 PM
Deanoo's Avatar
Deanoo
Default Convertable top problem
I bought a used top for my 59 and the front bow is angled wrong. It's hard to explain. It faces down ward. Could the header be on backwards? HELP
Old Feb 20, 2020 | 09:42 PM
woodsdesign's Avatar
woodsdesign
Please post a pic.
Old Feb 21, 2020 | 08:19 AM
CaptainEgg's Avatar
CaptainEgg
Almost Retired
Yes a picture would certainly help or a general area where you are so someone could come by and take a look
Old Feb 21, 2020 | 09:32 AM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
No the header can't be on backwards, it won't go on backwards.
In all probability you either have the top not adjusted correctly or you have brackets that are bent.
IMHO,
Willcox
Old Feb 22, 2020 | 09:30 AM
woodsdesign
Your header weatherstrip is on backwards. Turn it around the thick part should be facing to the inside.
Old Feb 22, 2020 | 10:16 AM
rsavage1's Avatar
rsavage1
More photos of the entire top- the header both inside and out might be more helpful.
Old Feb 23, 2020 | 08:11 AM
CaptainEgg's Avatar
CaptainEgg
Almost Retired
Yes the header can go on backwards, don't ask how I know!
Old Feb 23, 2020 | 05:20 PM
Deanoo's Avatar
Deanoo
Great!!! How do I turn it around. I'll try to post more pictures. Been fighting with the doors and panels. Repainted it and this car really sucks putting it all back together. OMG. Everything is a fight. My 56 Chevy pick up has better hardware. It's a retromod. The body and most of the interior is stock. I'm waiting for dash cluster parts, so I'll be working on the top in the morning. i'LL need lots of prayers. Thanks Everyone for your help. Great site....
Old Feb 23, 2020 | 06:09 PM
woodsdesign
In my opinion the header fit will improve greatly by installing the weather strip correctly. It is meant to wrap around the windshield header. So, I would remove the w/s by picking out the staples. I use a small pointed screw driver, I grind the end to a point to pick out the staples. Inspect it and replace if necessary. ( $20 max ) . Re position and re staple the w/s in place. Adjust the front latches.
Old Feb 24, 2020 | 05:00 PM
Deanoo's Avatar
Deanoo
Ok I pulled the rubber weather strip. It was just glued on with about a gallon of silicone, I see what your talking about it being on backwards. I posted more pics. I"ll be working on it in the morning. This is my car that I built from scratch. I pieced the body together and bought all the little parts one at a time. Took 5 years to get everything. It's on a custom chassis and I'm using a 2004 vette motor bored .030 over. I built the motor in my garage and built the car after I lost my job. (back surgery). Ford 9 inch and 700R4 trans, Wilwood brakes, Flaming River steering stuff. Carb set up. That's why I'm using the scoop out of a Trans am. The engine sat to high with the carb on top. Ok. Wish me luck on the top. Thanks everyone for your help.
Old Feb 25, 2020 | 09:09 AM
woodsdesign
That is a classic case of someone who doesn't want to take the time to do the job correctly. There is a tack strip on the underside of the cloth with about 11 or 12 sliding nuts. It is one of the worst parts of installing a C1 top ( IMO). I use an exacto knife and cut away the cloth for each sliding nut. There is also a retainer ( that you are missing ) and of course screws to hold it in place. The problem is that many times the tack strip is old and needs to be replaced. If that is the case you will have to peal back the cloth and install a new one ( which can be a difficult job ).
One easy fix is to staple the w/s on. It is not a very good fix but can work in a pinch. Don't forget to use screws on each end of the w/s. They will screw into a hole on the underside of the end caps.
Also, there is a flap that should wrap around the leading edge of the frame by the front edge of the window. It looks like it is still there but tucked under. This will give the top a cleaner look.
This is just one reason that it is expensive to install a top on a C1. This kind of work takes a long time. If it were me I would suck it up and do it correctly using the retainer and forget about it.
Feel free to PM me if you need help.
Larry
Old Feb 25, 2020 | 05:06 PM
Deanoo's Avatar
Deanoo
Woodsdesign, Thank You for your help. I had to retub the trunk now that I have a top that needs to rest in when lowered. Fiberglass is a norm for me now. In the beginning I wasn't going to use a top, but changed my mind. I bought the top used for $1500. I thought I could just drop it in and go. Not so...LMAO. Thanks agian
To Convertable top problem
