[C2] Paint mega problem
If its letting go and cracking in a few places its all set to do it elsewhere....my topcoat WITH the primer started lifting off in sheets as big as 4" x 6"; I chased spot repairs until the car was completely stripped and resprayed.
Later during rebuild I took off the paint completely (was the plan anyway), it came off in printer paper sized strips. Looked like yours, and Frankie's.
The previous paint shop had put body filler, primer and finishing coats simply on top of the original color coats (there were about 3 of them from consecutive resprays ). Modern times paint technology on top of less modern times paint technology usually does not work well.
So I am afraid your paint shop won't have too much good news.
My techs have been in the restoration business for decades and needless to say telling them they weren't mixing material correctly was not recieved well. My headaches aside, I would urge you to question the next shop. And for what is worth, I will not warranty my paint unless I remove previous filler. A proper repair like this will not be inexpensive.
no impact. Car hasn’t left garage.
Haggerty paid $5k. I put another $5k in. The painter didn’t want to paint over the existing finish (which had zero adhesion issues it was done right. Sealer, primer, color, clear.
His theory is heat cold cycles. His paint adhered to the existing paint, then shrunk pulling the older paint off.
My theory is the mix was too brittle (too much reducer?) the car chips like a ******. (Doesn’t ding, it chips at the slightest impact.). But I did not want to pay for stripping it again. It had one paint job that only had one fender screwed up from azzhat. Otherwise it was good.
With the amount of work in this car, it will get repaired. It’s a driver/restomod. Not looking for perfection.
The plan is to let the car bake in the sun for a bit, finish all mechanical work and then redo the back and do some spot repairs. I trust this guy. He is as **** as they come. Mixes his own paint (has the whole computerized rig to do any color matching.) owned a boat shop doing boat finishes and painted graphics and Corvettes.
I cant hold it against him. The paint is only as good as what is under it although I think the clear coat is too brittle. I have to live with it for a bit. Frustrating as hell.
If it chips bad, it isn't adhering to it substrate.
The reasons are numerous and debatable, too fast of cure, wrong substrate, too smooth substrate, incompatible substrate, whatever. A very good painter (Ferrari certified) I know has said many problems occur because people mix products, PPG primer and Sikkens paint, for example, rather than sticking to all PPG or Sikkens or whatever; manufacturer name isn't important, using products from the same manufacturer is. There are painters who can follow directions and there are painters who think they know more than the people who made the paint...
A long time a ago, a friend had his 65 Mustang stripped and painted. A year later, he took it toethe quarter car wash,and as soon as he hit the paint with the water, the whole paint job flew off in huge sheets leaving a red primer behind. Why, i don't know.
Doug
"Haggerty paid $5k. I put another $5k in."
It looks to me that Haggerity OFFERED $5000 and you accepted it.
If the true cost to repair/refinish was $10000, your painter should put in for a supplement.
One should never accept an insurance company's offer unless the invoice for the repairs is no more than the cost.
Your assuming the addtional 5k was just paint
It had a modern color/clear PPG paint job from 12 years ago. Shot it myself after removing six paint jobs with a razor and then bringing all the sharp lines back. Then, three years ago, it was sideswiped (hit and run) and sustained a gouge in the pass fender.
Paint could have been old or gotten too cold at one time
Old reducer or old hardener
Improper mixing or ratios
Strip it off - fix it and blend it in.
Paint is fickle
