[C1] Help on 2 fronts
Old Mar 23, 2020 | 04:10 PM
kinabub's Avatar
kinabub
Default Help on 2 fronts
I have a memory like a flash bulb!
power antenna for my 61. Not too long ago there was a discussion regarding this. As I recall Frankie had an input. I don’t remember the details and can’t find it.
#2 How to “search”. Can someone give me a tutorial on how to search the forum please. Use my request about the power antenna as an example if that would help.
thanks in advance
Old Mar 23, 2020 | 04:47 PM
Hermn59's Avatar
Hermn59
One should help out with the other.
https://www.corvetteforum.com/forums...to-search.html
Old Mar 23, 2020 | 09:04 PM
kinabub's Avatar
kinabub
Old Mar 23, 2020 | 09:41 PM
DZVette's Avatar
DZVette
Kinabub,
I put together the attached tutorial on using the search function on the Forum.
Give it a look-over, follow the steps and let us know if it helps you run a search.
Dave Z
File Type: pdf
Old Mar 24, 2020 | 08:02 PM
Frankie the Fink's Avatar
Frankie the Fink
Army
I used the METRA 44 PW-22 power antenna on my 61; its commonly available, flush mounts and fits under a C1 rear fender easily.
Old Mar 25, 2020 | 03:18 PM
kinabub's Avatar
kinabub
To Help on 2 fronts
