Hey guys cold start question. Forgive me, I am new to older engines. But am just looking for advice on this one.
Basically I have a 283 in my C1, It's doesn't really start when cold. The Vette does have a fuel pump that won't start until oil pressure is reached. I'm not sure if this is normal. Any way last season I had an issue with starting it warm and cold. I adjusted the timing yesterday and had successfully warm starts. What should I be looking for with the cold start issue? Thanks everyone!
Have you read the owner's manual yet by any chance? There is a paragraph or two in there about starting the engine cold/hot. Quite a bit different than starting a new car but just as easy.
If you are not driving the car every few days, and it sits, the carburetor will be bone dry, as the new gas evaporates. The cure is to drive more often. Also, make sure the choke is functional and adjusted properly.
Especially if his car has an AFB carburetor but I doubt his C1 has one of them. WSFB's aren't all that bad about the gas evaporating out of th float bowl.
If he is used to the "no touch" starting like new models, he needs to bone up.
A couple pumps from the gas get it primed well without using the choke. I suppose my issue last season could have been related to the battery. I did keep the battery on a charger all winter. And it seems to be stronger now. Thanks for the help.
If the fuel pump won't activate until the oil pressure is up as he states then its an aftermarket electric pump and there is no telling what other mods he has...
Could be, especially if someone removed the manual pump.
That would do it, or as GTOguy said, it could be because the fuel bowl is empty. I wasn't driving my car a lot and the fuel would evaporate requiring a lot of cranking to get it to start. I haven't had that problem since converting to a Holley Sniper with the Holley in-tank fuel pump.
I had a heck of a time cold starting my 62. I treid everything. When friends would come and try to help it started right up and it became the joke of the club. Then one night I got to thinking---every time someone came to helo the first thing they did was to remove the air filter---hmmmm! So, the next moring I removed the filetr and bang---popped right over and worked great. So I looked a little closer and low and behold I discovered that the when I tightened the wing nut on the air filter the little dome in the center pressed against the choke rod. That also would explain my difficult hard starts after the engine warmed up.
I put a stopper nut just high enough to prevent the propblem but not so high as to prevent closing the hood.
Problem solved--cold starts fine warm starts fine AND much better gas mileage----it gets as good as my brother in law's PT Cruiser---16.8. For a PT Cruiser it's embarrassing and terrible but for a 327 Corvette that's great .
Check that out. Ya might get lucky.
Eddie
I do have an after market fuel pump that does not sit in the tank. This car is a 54' and was my Grandfathers. He did a 283 swap with a T500. I was concerned because I would think I should get fuel pressure once I turn the ignition on, not after I get oil pressure. I will check out the filter situation too, I didn't think to look for how the filter is affecting the choke.
My plan is to start it and run it once a day here, and continue to trouble shoot. Thanks again for all the input!
As a safety precaution, some owners wire the electric pump through the oil pressure sending unit. If the engine quits in the event of a wreck, the pump will stop pumping fuel.
If the long crank time bothers you, you can always manually prime the carburetor before trying to start the car. I suppose you could also put a manual override circuit on that fuel pump to fill the fuel system without even cranking the engine.
