temp guage issue
Old Jun 18, 2020 | 08:01 PM
Mikesa's Avatar
Mikesa
Default temp guage issue
Anyone experienced a temperature guage that the pointer slowly moves counterclockwise down to about the "6 o'clock" position when the ignition key is turned off and moves back to the proper, just under 100 degree, position when the key is turned to the on position. After driving, the guage hardly moves at all when the engine reaches operating temp. This is a new guage recently purchased from a high profile corvette supplier. The guage was replaced during cluster restoration due to original fading, but the original one worked perfectly. Before I assume it is defective, I thought I'd toss it out there in case anyone has experienced it, or has any thoughts.
thanks,
Mike
Old Jun 18, 2020 | 08:25 PM
dplotkin's Avatar
dplotkin
2015 C2 of the Year Finalist
Mike
Which explains it. Do a search here, several threads exist that discuss your issue with reproduction instruments. Hope you kept your old one...
Dan
Old Jun 18, 2020 | 09:20 PM
Mikesa's Avatar
Mikesa
Dan
I did. Thanks Dan, I'll do some searching.
Mike
To temp guage issue
