Decoding numbers C1/C2
Old Jul 5, 2020 | 12:19 PM
Drummer Boy's Avatar
Drummer Boy
Default Decoding numbers C1/C2
Good morning all,
In the middle of an engine/gear box rebuild and came accross two numbers that I can not translate.
The engine is a 327/350 bored .030 over and had been ballanced many years ago. When I turn the bock over I can clearly see the numbers that the balancer stamped into the block next to each piston/crank location.
Unfortunately when this engine was machined, the machinist ground off the numbers just in front of the passenger side valve cover and they are lost forever so all I have to go on is the casting number on the rear of the engine:
389 2657 which tells me that this block is from a 66 something or other.
At the very back of the engine o the corner of the block is stamped: IO 6 F and while all of the balancing information is very easy to translate, I do not understand this sequence.
The Gear Box is Muncie M-20 all of the numbers make sense except --at the top of the main box are the numbers:
K 195 083
Any insight would be welcome.
Eddie
Old Jul 6, 2020 | 02:01 PM
MelWff's Avatar
MelWff
Concerning the I0 6 F, post a picture that format does not make sense.
Concerning the transmission date codes start with the letter P.
see this thread on the block casting number
https://www.corvetteforum.com/forums...-or-large.html
Old Jul 6, 2020 | 02:55 PM
Rumblegutz's Avatar
Rumblegutz
3892657 is a block casting number. It is generally a 1 model year only block. The model year is 1967. There might have been some very late '66's that received this block. But that may be unverified.
You need to supply the block casting date.
Photos of any numbers is the best way to reduce much of the guess work.
Old Jul 6, 2020 | 03:17 PM
jim lockwood's Avatar
jim lockwood
C2 of Year Finalist (track prepared) 2019
Originally Posted by Drummer Boy
Good morning all,
K 195 083
Eddie
Those are number stamped by GM, not the person who did the engine balancing. The represent information for the engine assemblers regarding which pistons to fit in which holes.
To Decoding numbers C1/C2
