[C1] Dynamat Install
Old Jul 24, 2020 | 03:19 PM
vetintheblood's Avatar
vetintheblood
From: Beavercreek Ohio Currently own: 1958 Silver Blue Corvette & 1969 Riverside Gold Corvette Coupe
2025 C1 of the Year - Unmodified Finalist
Default Dynamat Install
Hey all, has anyone out there dynamat-ed the floor of the C1?
My firewall insulation is deteriorated and I am curious if installing dynamat insulation in the firewall area is adequate in place of the firewall insulation.
Old Jul 24, 2020 | 03:27 PM
GTOguy's Avatar
GTOguy
Dynamat is a noise supressor, mainly. And very much overpriced. We did an entire GTO with Frost King for under $40. About 80 to 100 times cheaper than Dynamat.....and it keeps out the heat as well as the noise. Still tomb-quiet 9 years later.
Old Jul 24, 2020 | 07:05 PM
vetintheblood
Has anyone had to replace the interior firewall insulation?
Old Jul 24, 2020 | 11:04 PM
gleninsandiego's Avatar
gleninsandiego
Dynamat is good stuff - but it alone won't kill the heat. It is more for accoustics
Dynaliner on top is what you want for for heat
Both are pricey
Old Jul 24, 2020 | 11:17 PM
59BlueSilver's Avatar
59BlueSilver
2023 Restomod of the Year Finalist
I agree, Dynamat is overpriced. I too did my 59 with Frost King and am very happy with it.
Old Jul 25, 2020 | 10:02 AM
CaptainEgg's Avatar
CaptainEgg
Almost Retired
When I google Frost King it comes up with lots of home products but nothing that I saw that could be used in a car. Is there another Frost King out there?
Old Jul 25, 2020 | 10:31 AM
Pilot Dan's Avatar
Pilot Dan
I used jute padding from a roll I had to replace all the crappy brown stuff that was falling down in my 64 from under the dash. Nice part of working with a roll is you can make your own pieces and work in small sections at a time. On a C-1, there is no insulation on the underside of the dash, just the firewall and it's molded pieces with a hard backing. If your original is not too bad, I'd leave it alone and just do the floors and doors.. They do make a nice reproduction, but it is a bit of work to install it since you have to take everything out to get the pieces in the way the factory did.
https://www.zip-corvette.com/58-59e-...nsulation.html
Old Jul 25, 2020 | 12:21 PM
59BlueSilver
I believe this is it. I ordered a roll and should deliver today. Will let you know if it’s not the right stuff.
Amazon Amazon
Old Jul 25, 2020 | 01:20 PM
GTOguy's Avatar
GTOguy
Originally Posted by 59BlueSilver
I believe this is it. I ordered a roll and should deliver today. Will let you know if it’s not the right stuff.https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
That is EXACLTY the stuff. Hint: use a tire patch stitching tool ( a serrated metal roller wheel on a shaft) to press it into corners and nooks and crannies. A regular small paint roller works for the big areas, but you need the tire stitcher (looks like a pizza cutter without the sharp cutting edge on the wheel) to really get a neat install around the corners, etc.
To Dynamat Install
