Help! no start
Old Jul 25, 2020 | 03:16 PM
lonzoo's Avatar
lonzoo
Default Help! no start
Took the 63 out today for a while. Car started up with no problem. Drove about 20 miles and stopped to chat with friends.. when back to start it up and nothing. Gauges and radio worked fine but nothing when I tried to start it. Friend had older jumper cables but could not get it to do anything. We pushed it and dropped clutch and it fired up. Drove back home and and it started but battery did not act like it was charged..just barely turned it over before it fired up. I am charging battery now. Could I have an alternator problem or voltage regulator bad?? Not too good on electrical troubleshooting but is there any simple tests I could do to determine what is going on? Thanks for any advice
Old Jul 25, 2020 | 03:23 PM
JF in MI's Avatar
JF in MI
Pro Mechanic
2023 C1 of the Year Finalist - Modified
I'm betting on starter, brushes in particular.
Old Jul 25, 2020 | 03:28 PM
Tampa Jerry's Avatar
Tampa Jerry
I would start with a volt meter. Once the battery is charged, before starting, check the voltage of the battery. It should be 12.25 to 12.75 volts. If the voltage registers below 12 volts, replace the battery. Once it starts, the voltage should go up to 13 plus volts to 14.5 volts. If not, either your alternator or voltage regulator could be at fault. Lastly, have you checked the red wire connection on the firewall side just below the master cylinder? Do a search on the forum for the red wire problem. Jerry
Old Jul 25, 2020 | 03:47 PM
lonzoo's Avatar
lonzoo
Battery almost completely charged now....Getting 13.1 volts not running and 14.3 when running.
Old Jul 25, 2020 | 03:53 PM
plaidside's Avatar
plaidside
Tampa Jerry is spot on. Now you know your charging system is OK you should check the firewall connector.
Old Jul 25, 2020 | 04:08 PM
lonzoo's Avatar
lonzoo
When firewall connector problem would gauges and radio still work.. I noticed that the amp gauge would go instantly to full discharge when I had ignition in the start position.
Old Jul 25, 2020 | 04:25 PM
Pop Chevy's Avatar
Pop Chevy
2021 C1 of the Year Finalist - Modified
That points you toward the starter.
Old Jul 25, 2020 | 04:44 PM
aclassicnut's Avatar
aclassicnut
Veteran: Marine Corps
Veteran
How ood is your postive red wire from the battery to the starter? Check the voltage at the starter teminal
Old Jul 25, 2020 | 05:40 PM
65GGvert's Avatar
65GGvert
Every symptom you have points to the starter.
Old Jul 25, 2020 | 05:55 PM
GTOguy's Avatar
GTOguy
Or the hot wire to the starter solenoid. Or the connection at the ignition switch. Or the positive battery cable. Or the grounds.....etc.
Old Jul 25, 2020 | 06:07 PM
lonzoo's Avatar
lonzoo
Thanks for the help guys. Tomorrow I will test the solenoid connection and the battery cable voltage. If those check out looks like a new starter is the route to go.
Old Jul 25, 2020 | 06:13 PM
Captain Bud's Avatar
Captain Bud
2020 C1 of the Year Finalist - Unmodified
Had a similar problem on my Avanti ll that had a 350 Corvette engine. The starter got heat soaked and it wouldn't do anything until it cooled down.
They make a thermal blanket to cover the starter that solves this problem.
Old Jul 25, 2020 | 06:30 PM
65GGvert's Avatar
65GGvert
Those things won't make the batt gauge full negative when you turn the key to start. only too much current going to the starter with the starter not moving will cause that
Old Jul 26, 2020 | 07:46 PM
lonzoo's Avatar
lonzoo
Update; Checked positive to starter..getting 13v. Bulk connectors all look new with no arciing marks. Alternator putting out 14.3 v. I even removed ground cable on battery with motor running and it never died. Thats telling me the problem is either solenoid or starter. Sounds like new starter w/solenoid may be in order. although it has started right up on several tries today (another indicator starter going bad). Thanks guys for all your input.This forum is great.
To Help! no start
