[C2] Problems starting 66 L72
Need your help! Finally got my 66 L72 Vette after almost 3 months of shipping and logistics to get her registered here in france. My Vette is a matching numbers fully restored by nabers brothers back in 2015 and since then she’s been pretty much a trailer queen with less that 1000miles in 5 years. So after arriving at the local garage who specializes in classics had it fully looked over and there was lots of loose screws undercarriage but nothing major. Battery fully charged and all checked fine till now. I’ve put about 50 miles on her in about 2 weeks of casual driving and now when I try to start, I get a clicking noise after turning key several times but no engine turnover. Give it gas twice and turn key several times but no start. After a few second several tries of turning key, she finally turns over and starts. Only seems to occur when cold as she starts up immediately afterwards. Took her to garage and he believes it’s starter suggesting to replace it. I believe starter was rebuilt in 2015 when restoration was done. Anyone believe it’s something else? I recorded video and placed on YouTube if you’d like to see problem-
Totally agree with 65GGvert. Sure sounds like a bad battery connection either at the battery but more likely at the starter as these connections are rarely (if ever) cleaned (until there is a problem). Once the connection was made, the starter sounded like it spun up to speed properly and the car would have started easier if you hadn't flooded it by pumping it so many times. To start these bad boys you just turn the key to start and when the starter winds up, pump the pedal a couple times. That it.
So what it reads like to me is the solenoid contactor is corroded by arcing and either needs to be replaced or you could try and remove the solenoid cover and flip the contactor disk over using the other side. Something I found once for guest with that problem and I could only get at one of the cover screws is I removed the one screw and pried the cover open enough to squirt in contact cleaner from a aerosol can. It worked though I don't know how long it lasted. Here in the states the local parts stores will have everything from a whole starter to just the contactor disk on the shelf - but in France you most likely will have to order and have it shipped.
Hope this can help.
