c 3 Covette 1963 split window
I’m moving this over to the C1/C2 Corvettes section for some help with your pricing questions.
The Car got the lifetime award x2 and the Dunforth award should I be getting it judged again in Canada it was 2012 that it attained these awards and as ou have C 1 corvettes do you find that they go up in value when you keep them for along time or any recommendations for me
I am sure the car has a lot of history. YES,......... Good value, and very expensive, even if you can see out the rear view mirror split window.
2012 was the NATIONAL CONVENTION in San Diego
Hagerty says in Concours condition a '63 SWC is valued at $148,000; in Excellent condition a current value is $102,000. Of course there are Value Adjustments dependent upon equipment (value goes down for PG or 3-speed trans; up for power windows, etc).
There is currently a Triple Crown winner for sale in Charlotte, NC for $160,000; so, a lot of value depends upon condition, awards, options, etc. Again, looking to Hagerty, factory A/C in this car is a $12,500 add, and factory knock off wheels adds $10,000.
For the Corvette you are interested in you mention awards. I assume you are saying the car has won 2 NCRS Top Flight awards in 2012. I think you are also saying it has the Duntov award? (Not the Dungoth and Dunforth awards you mention). However, an important question is has the Corvette been maintained in the same show winning condition? It can lose significant value if the condition has dropped from its prior award winning state.
As you can see, value now and projected value for the future is a broad subject.
Hopefully, some of the other members can provide even better insight for you.
Edit: Apologies, Jim. I did not see your entry at the time I typed mine. (Slow typist.
). You provided a much better and more comprehensive response and I'm sure the OP will appreciate and benefit from your great info.
Second, you are buying a “trailer queen”, your obvious concern about a car with prestigious awards keeping its value is diametrically opposed to using it regularly IMO. My split window is worth double percentage points less but I can hop in the seat and cruise anywhere. Know what you’re buying.
TonysCorvettesShop. I had him inspect a 55 for me. Money well spent as I avoided purchasing
a poorly restored car that couldn't be fixed.
If you are considering spending $100k+ on a 63 SWC why not have Tony inspect it for you?
He has restored hundreds of national top flight vettes.
https://www.tonyscorvetteshop.com/
What are your intentions for the car? As FtF notes, if you are going to drive it, a Duntov award winner isn't really a good choice, especially if you are hoping to retain its value.
