[C2] Detonation vs Forging marks?
Old Oct 24, 2020 | 04:55 PM
Robert61's Avatar
Robert61
I have no idea what part of Florida you're from. I don't personally know any engine shops there. Surely there's enough folks here that could tell you where to go and where to avoid. Just looking at their equipment RPMperformance1 in Ft Walton has some nice stuff and usually you don't have equipment that nice unless you have a pretty good idea how to operate it.
Old Oct 24, 2020 | 06:16 PM
6T7L71CPE's Avatar
6T7L71CPE
Sent you a PM
Old Oct 25, 2020 | 11:47 AM
GTOguy's Avatar
GTOguy
Old Oct 25, 2020 | 12:44 PM
6T7L71CPE's Avatar
6T7L71CPE
Originally Posted by GTOguy
Hey you found my house, Damn Google Maps..... I actually drove around looking for that house back then, can't remember if I found it, can't remember a lot of things some days!
That scuffing looks pretty light, and it looks like you have little or no ring ridge. I would measure the cylinders for taper and wear and go from there. My '61 had a similar condition with 30%+ leakdown in every cylinder and blowby and oil consuption....the rings were gapped at .044 and worn out, but the cylinders measured out fine. A torque plate hone and new rings and bearings and $700 later I had a rebuilt engine. What I'm saying is that you are absolutely on point freshening/rebuilding your present engine. And it may not need much more than a hone, new pistons/rings/bearings. Easy-Peasy.
This is what I was hoping for. But, I don't have bore gauges, FLAPS doesn't rent them, to accurately check the cylinders so I used the less accurate ring gap check. The #4 cylinder came out more worn than the others so that's why I started to question the detonation marks on the pistons. A machine shop will have to take accurate measurements before we can make that call. Thanks
Old Oct 25, 2020 | 03:43 PM
GTOguy's Avatar
GTOguy
If you take it to a good machine shop, they can measure the bores correctly and tell you what you have. If you have to punch it .020" or .030" so be it. You're getting new pistons anyway.
