'57 283 Engine Value
Old Oct 30, 2020 | 01:36 AM
dbrust's Avatar
dbrust
2nd Gear
Default '57 283 Engine Value
Hello!
I'm trying to find what the value would be for a 270 HP 283 factory mechanical cam dual quad manual transmission Corvette engine from 1957. I'm trying to decide if it's worth bringing a '57 with a 327 back to a year-correct 283, assuming that it's actually that. Any insight would be greatly appreciated!
Many of the relevant numbers are listed below:
Block............................... 3731548..... J116..... F1016EG
Rh exhaust manifold...... 3733976
Lh exhaust manifold........ 3733975
Cylinder heads ................3740997
Intake manifold............... 3739653
Water pump.................... 3738483
Rear carburetor........ 6-1299 top..... 049 mid.... 2613S
Front carburetor ....... 6-129 top...... 049 mid.... 2614S
Valve covers................... 3726086
Distributor ...................... 110891
Camshaft.........................3736097
Old Oct 30, 2020 | 09:08 AM
VETT457's Avatar
VETT457
Originally Posted by dbrust
Hello!
If the tags are correct the carburetors are not '57
Old Oct 30, 2020 | 09:55 AM
Panama 58's Avatar
Panama 58
Let me see if I can get the ball rolling for you. I will stick with the engine block because it's the foundation and everything else can be adjusted to be correct or match. I sold an original Corvette '59 270hp long block with correct numbers and original stamp pad back (with original pan) in 2010 to a guy that had the perfectly aligned VIN dated car for this engine. It was still standard bore, but needed a total rebuild. He paid $3,000. The two key factors now are, that was ten years ago and can you find a '57 owner that wants to invest the money to make his NOM car appear original again. Check the rest of the numbers and see just how close you are to an original engine. The closer you get the more money you can ask. Neither your block nor mine had VIN derivative's, so as long as the dates line up you are good. There are people out there that will jump on it, but they aren't actively looking because it's like a needle in a haystack. Post a pic of the stamp pad if possible.
Old Oct 30, 2020 | 04:32 PM
emccomas's Avatar
emccomas
The block and engine stamp, if original, are pretty rare items.
The 997 heads are VERY rare items. The exhaust manifolds are correct. The car tags numbers are correct for a 270 hp engine, but not a 57 vintage. I believe that these carbs started usage in 1958.
Water pump.................... 3738483 - should be 3736493, double check number again
I suspect that you meant to type
Front carburetor ....... 6-1299 top...... 049 mid.... 2614S
for both carburetors.
Valve covers................... 3726086 are correct, ARe the 7 find or 9 fin?
Distributor ...................... 1110891 - correct for 1957 (not added digit)
The block, if it is not a restamp, is worth decent money, but it is very easy to replicate / fake that that engine stamp.
The real value here are the heads. 997 heads are rare, one year only items.
The biggest issue is going to be finding someone that wants to restore a 57 Corvette to original condition. These days many people are turning them into resto-mods, and selling off the original parts.
Old Oct 30, 2020 | 08:26 PM
Dan Hampton's Avatar
Dan Hampton
2018 C1 of Year Finalist
There was a time when people would dump their 283 and pay up to replace it with a 327. Enjoy the car the way it is. Continue to search for the right engine if you are so inclined. If successful, put all the parts in a safe part of your garage and dispose of the whole package when you get ready to sell it. A 283/270 will never give you the same enjoyment as a muscled up 327.
Old Oct 31, 2020 | 08:56 AM
MikeM's Avatar
MikeM
Might depend on whether you want that added muscle in your wallet or under the hood?
Old Nov 1, 2020 | 10:17 AM
GUSTO14's Avatar
GUSTO14
35 years ago a good friend bought a very nice '59 Corvette that ran and drove well - with a SB 400 in it. He decided he wanted to put a more correct 283 in it and went about the task. He purchased three 283 blocks before finding one that could pass muster with the machine shop doing the engine work. These were not minor or cosmetic issues.
By the early 80's (albeit before internet) a 283 suitable for rebuilding was just plain hard to find. When he was done he said he'd never make that mistake again.
Granted, with the internet and the growing number of resto-mods, your odds of finding a suitable engine are, well, about the same as his were in '85. Probably doable, but it won't be inexpensive...
Good luck... GUSTO
Old Nov 1, 2020 | 11:35 AM
GTOguy's Avatar
GTOguy
Good luck... GUSTO
I was in the auto industry from '79-'96 in the public sector, and even in the early '80's 283's in customer cars were not common. 307's were much more common, as were 350's. 327's were pretty rare, too. I worked on maybe two 265's during that whole time. Had a good customer with a '58 Impala with the 283 and it ran like a watch. 2bbl with oil bath air cleaner. I tuned it up several times over the years.
I looked into getting the 'correct' block and everything else for my '61 when I got it 5 years ago wanting to get it back to original. Just the bare block was over 5k at Cranes....not counting everything else. When I realized my 383 ran just like I wanted it to, and that my trans and rear end were not matching numbers either, I decided to not worry about it and just enjoy the car. And I've enjoyed it ever since!
Old Nov 1, 2020 | 02:28 PM
68hemi's Avatar
68hemi
C1 of Year Finalist (performance mods) 2019
I can only tell you my experience. I had the engine that was in my 57 when I got it which was a good running, no smoking engine with carb, air cleaner, exhaust manifolds, oil pan etc. in other words a COMPLETE running engine that was NOT a Corvette engine but rather a passenger car automatic engine but none the less a 1957 casting number and Flint built. I advertised it here for about a year starting at $2500. reducing it several times until down to $1000. I finally sold it through my local Craig’s List to someone that just wanted a running engine for something that had no significant historical value.
Finding someone that wants/needs your engine with the date code you have is a crapshoot. Advertise it and maybe you will get an immediate hit or you may have the same luck I had.
Old Nov 1, 2020 | 04:39 PM
Panama 58's Avatar
Panama 58
As mentioned before, those 997 heads are very hard to find now and are very valuable. Over the years I have sold three matching sets each for $2500 to $3,000. I haven't seen any up for sale for a while, but I suspect they have at least held their value.
Old Nov 1, 2020 | 05:24 PM
68hemi's Avatar
68hemi
I have never had a pair but I hope they and other original type parts have held their values but from what I have seen and witnessed is not so.
The restomod craze has devalued these prices and have brought a lot of parts to the market at big discounts. Look what has happened to the price of nice original frames.
Old Nov 1, 2020 | 07:50 PM
GUSTO14's Avatar
GUSTO14
Hello!
Many of the relevant numbers are listed below...
I may be wrong, but the way I read the OPs' above post, I believe he is telling us he currently has "a '57 with 327..." and is asking if we could provide him an estimate of what it might cost to create a 283, with dual 4-barrels, that met the specifications of a '57, 283 with the specifications he has listed.
GUSTO
Old Nov 1, 2020 | 10:19 PM
jimgessner's Avatar
jimgessner
Default Production dates by vin #
OCTOBER 10, 1956 VIN #0177 to 0201 was made. October 12, 1956 , 0227 to 0252 was made. And Oct 15,1956 ,0253 to 0277.
I owned vin 0288. It was made October 16, 1956 along with 0278 to 0302. ALL PER MIKE HUNT SURVEY.
To '57 283 Engine Value
