Battery Drain
Old Jan 12, 2021 | 03:30 PM
milano maroon's Avatar
milano maroon
Alternator tested OK.
Removed my Wells solid state voltage regulator and after cleaning the points put my old Delco regulator on.
No battery drain.
Thanks to all of you for your advice.
Old Jan 12, 2021 | 03:50 PM
jim lockwood's Avatar
jim lockwood
C2 of Year Finalist (track prepared) 2019
Congratulations on finding the cause of the drain and thanks for providing an update!
Old Jan 13, 2021 | 11:00 AM
2KREDVert's Avatar
2KREDVert
That scenario doesn't speak very highly for the Wells solid state regulator. I would never get one over the stock regulator.
Old Jan 13, 2021 | 11:16 AM
dplotkin's Avatar
dplotkin
2015 C2 of the Year Finalist
The electronic regulators made for use with GM & Mopar alternators are generally pretty good, I've seen far more failures with mechanical units than the solid state variety. Electronic regulators do not survive polarity reversals, so watch your jumper cables!
Dan
Old Jan 13, 2021 | 12:33 PM
Frankie the Fink's Avatar
Frankie the Fink
Army
Originally Posted by dplotkin;1602828316[b
]The electronic regulators made for use with GM & Mopar alternators are generally pretty good[/b], I've seen far more failures with mechanical units than the solid state variety. Electronic regulators do not survive polarity reversals, so watch your jumper cables!
Dan
Absolutely. I run nothing but the Wells regulators and have since 2015 and have built several undetectable conversions using the original housing and base - no failures. There is no way a "vibrating points" regulator that may make/break contacts up to 120 times/second via its moving parts is more reliable than solid state switching and regulation.
