Ignition switch connector/plug
Old Feb 17, 2021 | 11:12 AM
jfr's 63swc's Avatar
jfr's 63swc
Default Ignition switch connector/plug
Hello all,
Does anyone know where I can buy a new ignition switch electrical connector/plug that connects to the back of the ignition switch on a 1963. In pulling my temperature gauge to fix it, I pulled the ignition switch for additional access and noticed that both the switch and the plug had obviously gotten a little hot and melted. I had a spare switch so I have replaced it but the connector remains damaged - it still functions properly but I would like to replace it for peace of mind.
Thanks in advance for the help!
Jon
Old Feb 17, 2021 | 11:58 AM
Frankie the Fink's Avatar
Frankie the Fink
Army
Prob can't buy one new, separate from an entire harness - recast your question and ask if anybody has a good, used original on an old harness..
Old Feb 17, 2021 | 12:34 PM
jfr's 63swc
Good suggestion FTF! Does anybody have a good used original from an old harness they would be willing to part with?
Thanks!
Jon
Old Feb 17, 2021 | 12:41 PM
Pilot Dan's Avatar
Pilot Dan
I'd be concerned as to why your plug melted. It would be an indication that there is resistance possibly due to internal corrosion of the wiring. If the plug is still getting hot, you should address that and find the problem.
Old Feb 17, 2021 | 01:07 PM
jfr's 63swc
I did disassemble the original switch and there was a fair amount of corrosion on the inside. But, yes that is a good suggestion. I will check the existing plug on the next startup and if it is hot, I will try and track down the problem.
Old Feb 17, 2021 | 01:18 PM
Factoid's Avatar
Factoid
Is a ‘64 the same as a ‘63?
Old Feb 17, 2021 | 01:36 PM
jfr's 63swc
I think so as the ignition switch itself appears to be the same.
Old Feb 17, 2021 | 03:22 PM
C2Scho's Avatar
C2Scho
Hi Jon,
There is no need to buy a used harness just for the ignition switch connector.
You can buy a new ignition switch electrical connector plug from American Autowire for $8.00 It is the plastic connector which goes on the back of the ignition switch. I know that it works for a 67 but not sure for a 63. It should be very close or you may have to make a slight modification to make it work for a 63.
I have included a link to the switch below. Have fun with it. C.J.
Part #500257
https://www.americanautowire.com/nsearch/?q=500257
I don't know how you guys with 63's do it. So many one year only parts; most of which are hard to find and very expensive. You guys have amazing stamina and endurance (and deep pockets).
Old Feb 17, 2021 | 04:25 PM
jfr's 63swc
Thanks but the connector in your link does not look anything like the original! I am not sure how it would work. Maybe the switch on a '67 is different from a '63 - just checked and the back of a '67 switch is different from a '63!
I think I will try to get an used original first if anyone has one!.
Last edited by jfr's 63swc; Feb 17, 2021 at 04:30 PM. Reason: added note on '63 and '67 definitely being different!
Old Feb 17, 2021 | 05:08 PM
C2Scho's Avatar
C2Scho
Sorry that one does not fit the bill. How about this one? Unfortunately I am not sure what a 63 connector looks like. Good Luck with it.
https://www.americanautowire.com/sho...on-switch-5044
Old Feb 18, 2021 | 05:24 AM
Frankie the Fink
Army
I didn't suggest he buy a used harness, the intent was if somebody had the connector by itself off an old harness... This is the only pic I have of one::
Old Feb 18, 2021 | 07:20 AM
jfr's 63swc
FTF - I knew what you meant! Thanks for the picture.
Certainly somebody has replaced their dash harness on a '63 or '64 and kept the old one! Anybody?
Old Feb 18, 2021 | 07:28 AM
Factoid's Avatar
Factoid
I did on my ‘64 and I have the connector. Unfortunately, my car and harness are in NY and I will not be back until May. Sorry man, I would send it to you if I was there. Assuming your wiring is still good, it is very easy to pull the wires and clip them into the new connector.
Old Feb 18, 2021 | 07:33 AM
Factoid's Avatar
Factoid
Just to be sure, here is a pic of my ‘64. Sorry for the blurry picture, I zoomed in. Does your ‘64 look like this one?
Old Feb 18, 2021 | 07:58 AM
C2Scho's Avatar
C2Scho
I'm sorry Frank. Poor choice of words on my part. I only meant that he may be able to buy something new instead of used. Just trying to help. Cheers. C.J.
Old Feb 18, 2021 | 08:02 AM
jfr's 63swc
Factoid, That would be it - looks like the '63 and '64 are the same. Thanks for the offer. I will continue to look and if I do not find one by May, I will let you know. I am happy to pay for the part and shipping!
Jon
Old Feb 18, 2021 | 08:11 AM
jfr's 63swc
C.J.,
Thanks for your suggestions, unfortunately, they will not work for a '63.
I would love to buy a new connector, I just can not find one!!
So, the hunt continues!
Jon
To Ignition switch connector/plug
Old Feb 18, 2021 | 11:07 AM
Frankie the Fink
Army
I get it my friend....when my bulkhead plastic connectors broke I had to buy the whole $129 Lectic Limited "repair kit" with new pins and all just to get a $4 piece of plastic...
Old Feb 18, 2021 | 12:47 PM
jfr's 63swc
FTF,
I get why Lectric Limited will not sell individual connectors, they want to sell full harne$$es and kit$ and $uch but it does not create any good will towards them when one only needs a small item. Are they the only company producing harnesses for our cars?
Jon
Old Feb 18, 2021 | 01:02 PM
wib1961's Avatar
wib1961
To me this situation of not being able to find new connections has always been a mystery. Especially since there are companies making reproduction harnesses. They have to have access to the connectors. I have been looking off and on for years for the ignition switch connector for my '61 to no avail. I just simply don't understand. One of the mysteries of the universe, I suppose.
