[C2] Wrong Inner Splash Shield?
Old Apr 10, 2021 | 11:39 AM
66softtop's Avatar
66softtop
Default Wrong Inner Splash Shield?
Decided to replace my RH front inner splash shield. My original came under a rust attack. I ordered one from Ecklers. What I received does not even come close to meeting their GM restoration parts. Mine has a rolled edge and their entire shield is flat. Any advise is appreciated.
Mine on the left, Ecklers on the right.
Old Apr 10, 2021 | 11:50 AM
rowingone's Avatar
rowingone
I have a 66 BB and mine is flat . . but I have factory side pipes so they may be different as I believe the non side pipe cars had a rubber gasket on them.
Old Apr 10, 2021 | 11:51 AM
Easy Rhino's Avatar
Easy Rhino
From: Middle TN by way of KY, OH, VA, IL, CA, FL, NY, SC, HI
N/m
But if the one of the right is wrong, then mine are also wrong, as they're both flat as a pancake.
Old Apr 10, 2021 | 11:56 AM
66softtop's Avatar
66softtop
Beginning to sound like mine is not so original after all. I have a 66 small block with sidepipes.
Old Apr 10, 2021 | 12:05 PM
rowingone's Avatar
rowingone
I think your original just got bent up at some point
Old Apr 10, 2021 | 12:20 PM
BB767's Avatar
BB767
Default Flat Splash Shields
Both of my '66's with small blocks are all flat.
Old Apr 10, 2021 | 12:48 PM
leif.anderson93's Avatar
leif.anderson93
OP,
The one on the right had side of your picture is correct for the RH REAR on a '64 - '67...not the FRONT, as you state. The FRONT shield looks like the one in the picture below. BTW, for the best fitting replacement parts for you C2, might I recommend shopping at either Long Island Corvette or Paragon...JMHO.
Old Apr 10, 2021 | 01:04 PM
66softtop's Avatar
66softtop
I believe the splash shield you are showing is for the RH outer fender shield.
Old Apr 10, 2021 | 07:44 PM
66jack's Avatar
66jack
Yup, and its missing the 'foam/rubber' thats supposed to be stapled to it...
Old Apr 10, 2021 | 09:14 PM
pop23235's Avatar
pop23235
My 64 has one like that - not flat.
Old Apr 10, 2021 | 09:38 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
not if it’s a side pipe car
Old Apr 10, 2021 | 11:31 PM
65 Pro Vette's Avatar
65 Pro Vette
C2 of Year Finalist (appearance mods) 2019
Splash pans are flat. Yours is damage.
To Wrong Inner Splash Shield?
