30k miles is nothing for most u-joints driven within design limits. If it were me, I'd get the car on a lift, get the needle out, and lube them. They'll likely go another 60k miles easily, if not more.
C1's came built with the shield in the tranny tunnel for the reasons they break. Those joints were solid spicers. I've owned and repaired many C2 and C3 with the hole on the left side jack stowage , battery box. They are a weak point for drag racing, and weren't designed for the quarter mile. If replacing with a zerk fitting U joint the fitting has to be placed on the compression side during acceleration.. I prefer and install spicers without a greasable zerk fitting. My preference due to expierence.
