Percolation solved for $20
This week I added a muffin fan to the outside ot the radiator frame to blow cold air on to the carb.
I used the existing cold air duct that goes to the heater box. By removing the end that goes to the heater box and routing it to the carb, now when I shut off the engine I can turn on this fan and blow cool air on the carb . Today I made a 10 mile run stopped at a restaurant turned on the fan and went in for an hour and a half, typically after this same routine it would take 4 cranks to fire. today started right away. when i drove home and put it in the garage the engine temp was approaching 200, shut it off , turned on the fan and let it sit for half an hour started on the first crank.
fan located on the outside of the rad shell, was able to get in there without removing the hood, had to insert from in front and then put up in place...
Cold air duct heading to carb
Going to carb
At the carb
One cable tie to hold in place.... snip this and the duct will go right back on the heater box...
The next part will be to move the switch inside the cab so I won't have to lift the hood to turn on and off. This might work for you, it took about 2 hours total to get working, hiding the wires might take longer if you're into showing..
Good luck fighting the battle of crappy gas..
Dave
Also no original parts were harmed to make this mod...
Good luck...
a 1/4 inch 30$ phenolic carb spacer/insulator and a 160 degree thermostat solved it all. carb was then always cool to the touch.
see jegs or summit....
For me this is a simple inexpensive way to overcome the percolation problem...
Could probably run it all day and still start the car...
Dave
So many threads on the CF about hot engine running problems seem related to fuel percolation, or other problems exacerbated by percolation. This fan cost me $16. I had everything else that I needed.
Glad it helped
Dave
OOPS, I see someone already posed a C2 question, but I guess there isn’t a satisfactory solution with out some non stock equipment. Mine has the fuelie air intake in the radiator support, but a duct would really look out of place.
OOPS, I see someone already posed a C2 question, but I guess there isn’t a satisfactory solution with out some non stock equipment. Mine have the fuel in air intake in the radiator support, but a duct would really look out of place.
Good Luck...
