Won't start
Old Jun 14, 2021 | 04:46 PM
JimSR's Avatar
JimSR
Default Won't start
Had dead battery put charger on. Charger shows full charge no juice to anything. Where do I look next. Thanks in Advance. Jim
Forgot to say it's a 63 327ci
Old Jun 14, 2021 | 04:58 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
check to see if you have juice to the red wire on the horn relay, and check the bulk head connector for the red wire terminal
Old Jun 14, 2021 | 07:36 PM
65GGvert's Avatar
65GGvert
Start by measuring the posts of the battery, not the cables the posts. Then measure from the positive battery post to the chassis ground and then from the positive cable on the battery to a good ground. If you have 12 volts there, measure for 12 volts at the red wires on the horn relay. You've probably got a corroded or broken battery cable or end. It could be either the positive or the ground cable. Use a meter, start at the source and proceed.
Push the horn button and see if the horn honks, if it does report back
To Won't start
