62 front end problem
Old Jun 26, 2021 | 10:38 AM
p7k3's Avatar
p7k3
Default 62 front end problem
I'm getting a vertical shake on my passenger side, car tracks straight and this only happens above 60mph. I replaced the tire and wheel but that didn't solve the problem.
What should I be checking?
Thanks!
Old Jun 26, 2021 | 04:49 PM
Plasticman's Avatar
Plasticman
Make sure that the shock is properly connected at both ends, and if it is, make sure the shock still "functional".
If the shock is non-functional (easily depressed & extended), just a very small imbalance or initial bounce will cause the wheel to start "bouncing" along, like a basketball.
Plasticman
Old Jun 26, 2021 | 08:26 PM
GTOguy's Avatar
GTOguy
Also check the kingpins for play. Wheel bearing too.
Old Jun 27, 2021 | 05:36 AM
p7k3's Avatar
p7k3
Thanks for the tips.
Old Jun 27, 2021 | 08:48 AM
CaptainEgg's Avatar
CaptainEgg
Almost Retired
make sure the weight is still on the brake drum. If it is missing only way to correct is new drum or find a shop that has the old style balancer that does it with the tire on the car
Old Jun 27, 2021 | 11:14 AM
DZAUTO's Avatar
DZAUTO
2026 Corvette of the Year Finalist - Modified
2025 c1 of the Year - Modified Winner
2024 C1 of the Year Finalist - Modified
2023 C1 of the Year Finalist - Modified
2015 C1 of the Year Finalist
When I modified the drums for my home made HD brakes for the 56, I took them to my machinist that does engine balancing, and he balanced them.
To 62 front end problem
