It was always my understanding that the resistor plugs lowered RFI emissions, but as you say they dissipate some spark energy. First OE use was 1969. It probably doesn't make much difference with TI because that system delivers double the spark energy of the single point system, which has less reserve energy.
BTW, two equivalents of the long discontinued non-resistor AC 45 for small blocks is the Denso W14-U and NGK B4.
I'm leaning towards the ngk, but they only offer a 44n(bp6es) and a 46n(bp5es) cross referenced plug. With TI should I go with the 44n since I already have a hotter spark?
Resistor plugs have a (smaller) secondary air gap vs non-resistor plugs which have none. If I remember correctly, one advantage was to reduce misfiring and cross firing from induced voltage from spark plug wire routing. But obviously, jumping the secondary gap results in less spark energy at the primary ignition gap inside the combustion chamber.
Duke or others will likely have additional information to share.
Larry
Duke
Thank you, both. I tried running the googler on "secondary air gap" and what that means but didn't come up with much (i.e., anything). What does secondary gap refer to?
I clearly remember the Hot Rod magazines back in the late 1960's showing the differences in spark plug design: resistor and non-resistor. Typically the drawings and info were from Champion. I still have the articles. Obviously a lot has changed and improved over the last 50 years regarding spark plug design.
I would personally say 44, especially if you actually drive the car as intended. But, let’s see what the more enlightened here have to say :-). (in my personal inventory all I have is 43s and 44s, never had the desire/need for anything hotter)
