Always like them so I recently bought a big block hood for my 65. Since the original 327 died years ago and was replaced with a 350, I have been kicking around the idea of changing the 350 out for a 396 or 427. I figure I would have to change the front springs out, unless I put in a big block with aluminum heads and aluminum intake manifold, then maybe I could get by with the same springs. What else was different? Would I need to change the rear end or the transmission? I have power brakes if that makes a difference. Thanks.
Beg to disagree. Big blocks rock. Extra work, yes but you’ll never regret it if you do it right.
“ Gee I really wish I had a sbc instead of this big block”. Said no one ever.
You'll also need to change the radiator support, radiator and fan shroud. Those are all unique to big blocks and the small block stuff won't fit. You will also need big block pulleys and belts. They are also not interchangeable with small block stuff. No need to change the rear end or transmission unless you plan to put huge tires on it and beat the snot out of it. Unless you have a weird PB booster, a factory one should fit with the correct valve cover on the driver's side (has a big "dent": in it to clear the booster).
Don’t do it. You will hate yourself. If you are looking for performance you can build a small block that will do everything the big block will do for you. Less expensive, less labor. From experience. Big blocks look great. They suck to work on in limited engine compartment space.
There is no clear cut answer to this. My stroked 396 small block has more HP and torque than any original big block and weighs about 100 lbs less. So my car is better balanced and faster than any original big block with no real changes necessary to the suspension or running gear. However, if you want to stroke a big block, clearly you can make it more powerful and lighter. But you will then need to change the suspension and running gear because the car was not designed for that level of power.
So it depends on what you want and there are many different ways to go depending on your tastes.
If you just want bragging rights to say you have a big block, then I cannot disagree with you. Big blocks do rock! If you simply want performance then maybe a stroked small block is the better way to go.
with all being the same I like SB ones. The best thing about a BB car is the hood.
Come on guys.
Where’s the big block fans?
I know you’re out there.
As I’ve said before, there’s room for everybody here, we just have to understand we aren’t all the same/nor do we think alike. Either you got a little one, or you got a big one….. I never wished mine was smaller (Just a little comic relief ).
I read your 396 SBC build posts. Dollar for dollar I would say my 496BBC in my 66 build was a touch cheaper and makes 100 hp & 100 TQ more with all off the shelf non custom parts and is dressed to look almost 100% like a factory L72 engine bay. As Corvette guys we can't bitch about cramped engine bays. This car platform has one of the most wide open engine bays around so SBC or BBC its really not even a talking point. You can make big power with a SBC these days, I have a 395 ci SBC in my Nova and it makes 813 hp/ 563 TQ which equates to 2.05 hp/ci but that is with zero off the shelf parts. BBC/SBC debate will go on even after we are driving electric cars, but I will say I don't think I ever heard one person say "Man I wish I kept that small block in the car"
I have always been a BB fan, and my plan is to remove the small block in my 65 and install a GMPP ZZ427 with aluminum heads and the new Tremec 5 speed. There is quite a bit to do for the change over but In my opinion well worth the work. I have nothing against a small block my 365 is a strong high winding motor, but it’s not a BB.
My original 327 got boxed up years ago and I put a 350 crate motor in. My brother has a big block C3 with side pipes and it sounds awesome, he calls my 350 a "beginner motor". Well I'm in the middle of a body off right now and am waiting on my 383 to arrive. Got to love the big blocks but I never considered going that route.
