[C2] Sway bars
Old Sep 30, 2021 | 11:28 AM
  #41
Patrick03's Avatar
Patrick03
Drifting<br><img src="/forums/images/ranks/2k-3k.gif" border="0">
Originally Posted by DansYellow66
I know Jim - my thinking is that on the street a little additional roll stiffness up front gives the perceived feel of better responsiveness in transition and a bit flatter cornering at low/medium speeds - which seems to me to be what he’s after. I didn’t hear that he plans to compete the car in any way. Not many of us - at least at my age - explore the limits of understeer/ oversteer of our car on normal street cruising. And in the event we misjudge a street corner or curve a little, we are better off with some understeer. Yes, on the track it may well not be as balanced or desired.
I probably should have put a 15/16 bar on my car as with aluminum heads/intake on the BB and no power or other weight accessories I’m probably not that far off of a SB car with a couple power accessories in weight. Either that or remove the rear bar. But I’ve made due with poly bushing on the front BB car. It’s close enough on the street.
Dan's message here is spot on for street driven cars. The perception of better "handling" will be there even if it really isn't the case from a track perspective.
Old Sep 30, 2021 | 11:50 AM
  #42
68hemi's Avatar
68hemi
C1 of Year Finalist (performance mods) 2019
Originally Posted by SWCDuke
Nobody knows, so you'll have to do the research and find out the answer. It took me about 2 years doing 4 events per year, 2 at Riverside, and 2 at Willow Springs, to get my Cosworth Vega totally dialed in back in the eigthtes. I started with tires, shocks, and alignment, and once I got that dialed in I worked on bars until I found the best setup.
You've received plenty of suggestions on tires, shocks, and alignment. So get to it, then start test driving. My bet is that you won't find any real need for different bars, but I suspect you just won't be able resist tinkering and will proceed to screw up the handling with aftermarket anti-roll bars.
Duke
Well, I may have confuse some people here because I am dealing with tw different cars here. One is my 1966 BB and the other is my 1965 SB.
I have a set of Avon’s on order but they are two months out. I will be ordering QA1 shocks shortly.
My SB car is in the body shop so I expect I will be making the changes to the BB first. Someone removed the rear sway bar from my BB car and I have a factory bar on order. The shocks will likely go on first or possibly the sway bar.
I have no plans to replace the front sway bar at this point on the SB car or to add a rear bar and will start with Avon’s and QA1 shocks after I his car is out of the body shop. I also plan to order a Blueprint 396 SB for this 1965 replacing the current original 300 h.p. engine so I have a lot on my plate in the near future.
Old Sep 30, 2021 | 11:52 AM
  #43
jim lockwood's Avatar
jim lockwood
C2 of Year Finalist (track prepared) 2019
Oh, I like that and I think you hit the nail on the head. "The perception of better handling". Folks in marketing are quick to tell ya that perception is reality. So if the user perceives the handling is better, then it must be. Even if the suspension change turned the car into an understeering pig.
Old Sep 30, 2021 | 11:53 AM
  #44
SWCDuke's Avatar
SWCDuke
Originally Posted by DSR
I'm not sure what the difference is between understeer / oversteer. .
My recollection of a quote from a NASCAR driver, long ago:
"Understeer is when the front end hits the wall. Oversteer is when the ***-end hits the wall."
Duke
Old Sep 30, 2021 | 12:32 PM
  #45
SWCDuke's Avatar
SWCDuke
My suggestion is to get the suspension components (bars) back to stock. The OE setup is the best baseline to start from. Get the Avons and shocks installed and get the alignment dialed in, Then do plenty of test driving over your normal roads to dial in the adjustable shocks.
The last thing to do is start swapping bars, and you need to understand what they do. Sure, they reduce roll, but they also have a big effect on the cars understeer/oversteer balance, which can vary widely among drivers. I recall long ago a Formula One driver had to use a spare car in practice that was set up for the other driver, and the first driver declared the car "undriveable".
I''ll add that on base suspension small blocks that can snap into oversteer at the limit, it's a good idea to install hard urethane bushings on the front bar links to the control arm. The rubber bushings can compress at high roll angles causing loss of bar effectiveness which effectively transfers roll stiffness to the rear, which is why they can suddenly snap into oversteer at the limit.
I don't have enough experience driving big blocks at eight or nine tenths, but it probably wouldn't be a bad idea to do the same. Public roads can be unpredictable, so its best to have a car with limit understeer and one that doesn't exhibit trailing throttle oversteer that can spin you into the weeds, a guard rail, or over over a cliff. Early 911s are famous for this trait due to both the rear weight bias and the toe and camber change of the semi-trailing arm rear suspension. The C2/3 three link rear suspension has similar unfavorable characteristics, which is one reason why they are very sensitive to rear toe and static rear toe must be in the proper range to avoid handling instability.
There's a reason why modern very high performance production and purpose built race cars have either a five link rear suspensions or upper and lower A-arms, which are the equivalent of four links plus a toe control link.
Duke
Old Sep 30, 2021 | 12:47 PM
  #46
tuxnharley's Avatar
tuxnharley
My take on this is that some folks perceive under steer as being better handling because it feels “safer” when they are at the limits of what they have experienced. At that point backing off the throttle is the instinctive reaction and understeer feels like the car is more predictable and therefore is thought to be better handling.
Comfort, predictability at the limits of one’s experience, and perceived safety are taken as better handling over actual cornering speeds and exit velocity. How many folks accelerate through a corner in street driving?
Old Sep 30, 2021 | 12:54 PM
  #47
68hemi's Avatar
68hemi
Alignment dial in? Can someone give me the specs for this regarding this thread.
Old Sep 30, 2021 | 01:04 PM
  #48
SWCDuke's Avatar
SWCDuke
Recommended alignment specs, both "touring" and '"sport" have been posted many times by me and JohnZ.
Duke
Old Sep 30, 2021 | 01:08 PM
  #49
jim lockwood
Um, I know a fellow who lives in the Sierra who does exactly that.
Old Sep 30, 2021 | 01:31 PM
  #50
SWCDuke's Avatar
SWCDuke
I always accelerate through corners. It's fun, especially 180 degree freeway onramps. I might enter a little conservative especially if I can't see the exit, but once I can see that the coast is clear I add throttle and take it up close to the limit.
Duke
Old Sep 30, 2021 | 01:45 PM
  #51
tuxnharley's Avatar
tuxnharley
Duke
Old Sep 30, 2021 | 02:04 PM
  #52
68hemi's Avatar
68hemi
Duke
Same here. You know those ramps are banked correctly. If I am on an unknown to me road I am careful not to accelerate in a hard turn for fear of the turn not being banked the correct way.
Old Sep 30, 2021 | 04:25 PM
  #53
63 340HP's Avatar
63 340HP
IMHO 3 degrees is a lot of roll. It makes for very slow transitions. It takes a while to get settled. That is pretty much what a SB C2/3 would do with stock springs and bars. It will use up over 1.7 inches of suspension travel in a turn and as much as 2.7" accelerating out of a corner, or trail-braking. You will be on the bump stops already. And if you hit a bump it will shoot into oversteer, and that might not be a great surprise.
For optimum street handling, and certainly for autocross or track use, I would cut the roll angle back by some. Maybe by 25% - 33% or so. Cutting it to 50%, well that is like an autocross setup. It would also handle/feel more like a newer Vette, and not spend so much time rolling around.
Feel free to check out the excel spreadsheet I wrote just for our C2 / C3s. Dynamic handling gets incredibly complex. This should help most with the math. I did spend 27 years doing Pro-Solo, tuning suspension, and road racing..... so....Enjoy!
(If someone thinks of something you want me to tweak or add let me know)
I have recommended your spreadsheets with links as they have evolved over in C3. It is a great tool to model and compare setups.
For the OP:
Know what you have in each car for springs, bars, and bushings, along with front/rear weight, and model them in the spreadsheet (Weight and Springs is the far left tab starting page).
On a C2 the inboard rear camber strut bracket produces a high rear roll center (promoting rear stiffness and snap oversteer). The C2 bracket also produces a less than ideal rear tire camber curve for anything other than the skinny 1963 tire profile (it moves a wide tire edge to edge as the suspension cycles). The lower C3 bracket produces a more stable camber curve to keep wider tires planted in fast cornering, and lowers the rear roll center for a more compliant ride. The C3 bracket also allows for slightly more rear roll and that shifts more load on the front bar & bushings to add more feedback with turn in understeer feel, in addition to reducing that snap oversteer concern (softer ride in a straight line and less surprise drama in corners). The C3 bracket, and lower aftermarket brackets, improve the handleing (model changes on the Spring Rate tab page).
Once the front and rear roll centers are set, get a performance alignment (-1* camber front, -0.5* rear camber, caster to your preference, and toe-in for your use, modeled on the Camber Change and Bump Steer tab pages). These settings will not change unless you change springs and ride height, so the tire angles and camber gain will remain consistent as you test bar and bar bushing changes (Sway Bar tab page).
If you swap springs, like the F41 springs that ride about 1" lower in front, the alignment should be adjusted for the new ride height (the ride height model adjustment is on the Roll Center tab page).
The Sway Bar tab page model assumes stock GM 6.25'/13.5" bar arm lengths. If you use an adjustable arm bar link mount (like old Rancho bars) or bars with a different pillow block to end link lever arm length, you need to change the sheet's "arm" values.
With modeling the difference in handling is quantified in the Roll Rate, from an ultra firm ride with understeer (C3 bracket F41 SB with 1 1/8" front & 7/8' rear Gymkhana bars @80% fr RR), to soft ride with potential snap oversteer (stock C2 bracket SB and no bars & base springs @45% fr RR).
Like any tool you need to test options on the pages and with your butt feel in the wild. Pick a desired roll rate & Fr/R balance, and then select the bracket and sway bars to fit and test.
Last edited by 63 340HP; Sep 30, 2021 at 04:34 PM. Reason: (stock C2 bracket SB and no bars & base springs @45% fr RR).
Old Sep 30, 2021 | 04:50 PM
  #54
leigh1322's Avatar
leigh1322
Old Pro Solo Guy
It is very difficult to change just one item on your suspension without improving or ruining it's balance. My bb car should roll 3 degrees stock. I do not want that much roll. My old pro-solo car I had roll 1.5 degrees. This one I want somewhere in the middle. I am going with 480 front springs, a 330 rear composite, front 1-1/8 bar, and 9/16 bb rear bar. That should make it roll where I want, more like a new car, and give me a similar handling balance to stock. The ride quality is 80% based on shock valving, that's why I have QA1 adjustables. That's last. I tuned my solo car's rear bar 100's of times to adjust the handling balance. And I raced 28 times a year. I began with a lot of rear bar and a very neutral car. I finally settled on more understeer than the factory had, because I learned to used full power from that LT-1 thru most of the turn. That was several seconds faster than a neutral car. And yes powering thru turns is fun, if you have enough power, you can walk the tail out any amount you want. I actually had to add more rear bar / oversteer to the car for the road course. I just didn't have enough power in 3rd to walk the tail out. If you are more gentle with the car, or have less power, you would also want more rear oversteer than I did. On the C3 LS6 I will just juggle bar size up & down fr & rr until I get it where I like it. The numbers say it's got a decent balanced setup but I am still building the car. I just wish I had an adjustable rear bar. Might be worth making one even. I did before.
I am glad to hear some feedback from some that are using the spreadsheet to model setups. You can change a few things at a time, and not ruin the balance, if you keep the fr roll % the same. Somewhere around 72. Look what GM did to the gymkhana cars 78% front, and less power. Too much understeer.
Old Sep 30, 2021 | 05:11 PM
  #55
SWCDuke's Avatar
SWCDuke
If you've never been on the road (or track) before you need to take it easy and "read" the road. Decreasing radius corners and off camber turns, especially at the exit can be real pucker experiences. Get to know the road or track and then figure out where you need to be a bit conservative and where you can really let it hang out.
Every track has "pucker" turn. At Riverside it was Turn 2 and the big Willow Springs track is Turn 9. I always thought I could do Turn 2 flat in fifth at a bit over 100 MPH, in the Cosworth Vega, but was never able to bring myself to it. I didn't brake but I did lift briefly before turning in. It was flat and went around a berm. You couldn't see the exit. I always thought about the Gile Villeneuve - Clay Regazoni story that was written up in one of the car magazines way back when.
Giles was the new guy and there was a corner at Ferrari's Fiorano test track he was having trouble with. He always lifted. Clay said, nah, you can do it flat. So finally on a lap when Giles was approaching the corner he placed his left foot over his right foot to lock the throttle pedal full on and did the corner flat. I guess my ***** weren't big enough to pull that stunt. The link to the You-tube clip is from circa 1988. I was running the best road tires from the late seventies/early eighties, Phoenix Stahlflex 3011s, and unfortunately I didn't get around to installing a real set of DOT racing tires until after Riverside closed in the late eighties or early nineties, I think they would have allowed me to do it flat with confidence. Turn 2 was critical to a good lap tijme because it determined your speed through the esses, especially in a low to moderate powered car where you were scubbing off speed a good part of the way, especially Turn 2.
I'll let you guys figure out which is Turn 2 from the following clip. This was a track time event hosted by the local Ferrari and Pantera clubs. The rule were that if a car caught you in a corner he was faster, so let him pass on the next straight even if you can out accelerate him. The a-hole in the 911 didn't believe in following the rules, and I cou'dn't get the corner workers or start/finish stewards to pay attention to what was going on and black flag the SOB.
The two top related videos on the right are me and a buddy drag racing our CVs at the old Brotherhood raceway at the LA harbor back in the early nineties and the next on is video from my incar camera and the supercharged small block Mustang that overcooked it trying to pass me going into Turn 7A.
Duke
Old Sep 30, 2021 | 06:36 PM
  #56
68hemi's Avatar
68hemi
Cool video. Yeah, that joker should have let you pass on the straight since you were up his *** on all the turns.
Old Sep 30, 2021 | 06:40 PM
  #57
68hemi's Avatar
68hemi
For the OP:
are you saying that the C3 brackets are a bolt in change you can make to a C2 without other modifications?
To Sway bars
Old Sep 30, 2021 | 06:51 PM
  #58
63 340HP's Avatar
63 340HP
Yes. Bolt in and reset rear camber.
Old Sep 30, 2021 | 06:59 PM
  #59
68hemi's Avatar
68hemi
Would you happen to have the part numbers and source of where to buy them?
Old Sep 30, 2021 | 07:04 PM
  #60
66427-450's Avatar
66427-450
Hemi - I’ve got one if you’re interested? I’ll post a picture of the difference …. the later model is flatter, in other words the differential end rod mounts are lower. I also have a thin 3/8” aluminum spacer, that goes under it to take it even a touch lower, I think I got it from Dick Gullstrand years ago (in the 70’s), it’s brand new.
