C2 Handling issue
Old Sep 29, 2021 | 08:26 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
Originally Posted by jim lockwood
How do you know the tires he ordered aren't round?
with all the recent (years) of problem with cokers why take a chance when your paying a premium for 15" tires
Old Sep 29, 2021 | 08:37 PM
jim lockwood's Avatar
jim lockwood
C2 of Year Finalist (track prepared) 2019
Answering a question with a question is a non-answer.
An answer with actual information would be: The tires he ordered are made by Coker and Coker tires have a poor reputation.
Old Sep 29, 2021 | 09:05 PM
bluestreak63's Avatar
bluestreak63
Did you look at the Cooper Trendsetter SE Whitewalls? I have them on mine and they’re just fine for everyday driving.
Old Sep 29, 2021 | 09:14 PM
dcamick's Avatar
dcamick
2019 C1 of Year Finalist (appearance mods)
Jim,
Breaks my heart (and my wallet) that I had to remove my BF Goodrich Silvertown Red Lines that came with my purchase with under 3K miles.... that (2) were out of round. It was a hell of a ride at 70 MPH.....Just seems like a ton of issues with those tires......I just left them on my America's Finest Bolt on's and put a cover over them....
Steve, you have made your purchase....and you might be good to go! I love the look of the red lines.......Speedway is a good Company. I sell safety product to them..... And they should stand behind the products they sell in case you have issues.
Old Sep 29, 2021 | 09:29 PM
Bob K's Avatar
Bob K
St. Jude Donor '11-'25
I recently ordered 8 BFG Silvertown Radials (4 red wall/4 gold wall) from JEGS. They sent me 2 tires that were over 1 1/2 year old. I cancelled the order and went with Diamondback Auburn. I’m waiting for them now.
Bob K.
Old Sep 29, 2021 | 09:36 PM
TCracingCA's Avatar
TCracingCA
Every Stock C2 Has handling issues!!!!!!!!
Old Sep 29, 2021 | 09:58 PM
jim lockwood
Originally Posted by dcamick
Jim,
The piece of actual information missing from NWM's non-answer was that the BFGs are made by Coker. I didn't know that. I don't buy reproduction tires. That said, Coker's reputation preceeds it.
Old Sep 30, 2021 | 12:07 AM
daytonablue64's Avatar
daytonablue64
Granted a tire that's beginning to come apart will cause handling issues.
But the perceived big change in performance leads me to put my money on loss of a trailing arm shim(s).
Shortly after rebuilding my rear suspension I experienced a very similar occurrence.
One day the car handled great, the next time I drove it was very wonky.
The original style shims can't be removed without removing the shaft the the arm pivots on. So they don't fall out
But they're difficult to deal with and virtually all rebuilds and most alignments these days will use slide in shims that need a large cotter pin installed to hold them in.
If the installer overlooks this or forgets to reinstall the cotter pin, the new style slide shims will eventually fall out and disappear one by one.
Depending on how many have fallen out you might even be able to wiggle the tires and feel the play ( which there should be none).
But checking for side play at the shims of each T/A is warranted.
Old Sep 30, 2021 | 03:54 AM
ghostrider20's Avatar
ghostrider20
New tires, Then get a 4 wheel alignment. Search out for someone knowledgeable about corvettes and that has done a few. The corner big box tire brakes and alignment shop is not the place. A competent chassis guy will look at the ball joints, steering, suspension, etc.
Old Sep 30, 2021 | 08:32 AM
DansYellow66's Avatar
DansYellow66
Originally Posted by steve66c2
I just purchased a '66 coupe, 327/350 HP, 700R4. Prior to buying the car, we put it on a hoist and thoroughly inspected everything. All appeared normal and the car performed fine during the test drive with the exception of a hard pull to the left when braking (probably a caliper issue)
Anyone have any ideas?
Re: brakes. Don’t assume it’s the caliper. Inspect the inside of the tire sidewalls at all corners for a trail of brake fluid that signifies a caliper piston seal leak. If all are dry and no fluid trails, the odds are that your calipers are functional. Brake pulling is very often a symptom of old, deteriorated rubber brake hoses. They may look OK on the outside but the inner lining may be breaking down and collapsing and holding pressure under vacuum at the caliper, or may have just collapsed and blocked fluid flow to the caliper.
Re: mono-leaf rear spring. Never had one of these but everything I have read is that they are very sensitive to shock selection and can be very bouncy, porposing motion with standard shocks. There’s a recommended shock for use with this spring which I don’t recall at the moment, but someone here will know.
Old Sep 30, 2021 | 08:39 AM
steve66c2's Avatar
steve66c2
Thanks for that info Dan. Based on what you told me, I'll probably just replace all the rubber hoses.
I will have to research the monoleaf/shock issue.
Thanks again!
Old Sep 30, 2021 | 08:42 AM
steve66c2's Avatar
steve66c2
There is a shop not far from me that specializes in Corvette service. Going there for alignment.
Old Sep 30, 2021 | 09:14 AM
  #33
steve66c2's Avatar
steve66c2
As far as the tires go, I've had Coker tires on two of my vehicles for some time now with no issues.
I have had two sets of wide whites on my '62 TBird without any problems and a set of redlines on my Nomad for over a year now. I just have not experienced the problems everyone is referencing here. Also, I thought Coker was the only source for redlines. Nice to know there is another choice now. I may try the Diamond Backs if I run into any problems.
Old Sep 30, 2021 | 09:38 AM
  #34
Nowhere Man
When your spending almost three times the price of normal 15” tires you don’t want to have zero chances of problems. The stories I read are enough to scare me DB tires have a great track record. I am pleased with mine
Old Sep 30, 2021 | 10:50 AM
  #35
tuxnharley's Avatar
tuxnharley
Thanks again!
If you are going to replace the flex brake lines I’d recommend using the braided stainless steel mesh lines that have a Teflon liner. They are virtually indestructible, impervious to oil and grease deterioration , and don’t bulge or swell .
Old Sep 30, 2021 | 11:00 AM
  #36
marshal135's Avatar
marshal135
Veteran: Marine Corps
With all the positive feedback on the Hankook series tires, I just found 5 at Walmart on line free shipping to my door at $79.00 a piece.
I ordered black walls in a 215/70/15 to go with my 65 knock off's. I like the simplicity of the look and I do plan on driving her so I wanted a dependable and reputable driving tire.
I agree that white walls belong on a Cadillac. The BF Goodrich's on there now are from 1988 and look great with less than 10,000 miles since installed.
I think for a 70's era Cragger mag wheel you can't go wrong with raised white lettering but not on my knock offs.
On my 68 big block that was wondering I filled the steering box with grease as it was dry and it was stable after that.
Marshal
Old Sep 30, 2021 | 11:21 AM
  #37
steve66c2's Avatar
steve66c2
That was my plan!
To C2 Handling issue
Old Sep 30, 2021 | 11:44 AM
  #38
inspectorudy's Avatar
inspectorudy
I don't know who will do your alignment but you need to ask them before the job to not proceed with the rear alignment if the bushings are bad. Some places will do the job even though it is useless if the bushings are bad. I just had mine done and the tech told me that he couldn't align the rear because I needed to get new bushings and he didn't charge me for it. I had a lot of steering issues when I bought mine but since I put in the electric power steering they have all disappeared. I can turn the wheel sitting still with no effort and the wandering at high speed I had is gone. I still need to get the steering box adjusted so that the car wants to return to straight ahead when pressure is released. I no longer have the sawing motion that I had before to keep the car straight. Just a thought if you don't get any relief it is something to keep in mind. I actually enjoy driving my car now, whereas before it was almost scary and constant work.
Old Sep 30, 2021 | 12:03 PM
  #39
Pilot Dan's Avatar
Pilot Dan
I would send them back and get better radials that are round
I agree, I dealt with a set of those tires recently (made by Coker) and they exhibited lateral run out on the balancing machine even though they were balanced to the wheel. Took them for a ride anyway since I was already on the hook and bad vibration above 50 mph (felt like driving on rough pavement). Luckily I bought them through Jegs, and they gave me a full refund and paid for return shipping too. Considered a manufacturing defect by the company.
Went with a set of Diamondback redlines and zero driving issues. I have purchased Coker wide whites previously that rode fine and balanced up with very little weights, but these redlines were a different story.
Old Sep 30, 2021 | 12:58 PM
  #40
SWCDuke's Avatar
SWCDuke
I wouldn't install those unless they meet the DOT standard and most don't. DOT compliant rubber case hoses sold by any of the major brake component manufacturers will likely outlive most of us.
Duke
