[C1] Windshield Washer Fluid
Looking for a little help. My windshield wipers are working but the washer fluid is not. When I press the button on the wiper **** nothing happens. What's really odd is that, after turning off the engine, washer fluid comes out of the washer nozzles for a few seconds. I confirmed that I'm getting good vacuum from the hose that leaves the hollow stud on the base of the carburetor (17 inches of mercury). I also confirmed that I'm getting vacuum on the hose that attaches to the back of the wiper ****. I'm thinking that my problem is in the coordinator on the wiper motor. If it is bad can they be rebuilt by a guy with average mechanical skills?
2021 C2 of the Year Finalist - Unmodified
C2 of Year Finalist (stock) 2019
2016 C2 of Year Finalist
Replace the hoses if old and brittle. Blow out the lines. Stick a pin in the washer nozzle holes. My old Bowtie 62 sat for over 20+ years. Had judged twice with no action. Then one day it decided to work on its own. I always used distilled water. Empty system in the winter if located up North.
The problem I had with mine is I think a ground thang. I think that button on the wiper switch connects to a lead wire on the multi pin plug on the wiper motor. When I rang it out it went to one of those pins. After cleaning off all the contacts it started working. Some one here can confirm if that button is a ground start pump connection.
