Fuel question
Old Oct 22, 2021 | 06:31 PM
jasonsamara's Avatar
jasonsamara
Default Fuel question
Finally we have a station in my area that has ethanol free gas. The problem is it’s only 87. Would it be better to keep running 93 with ethanol or use an octane booster with non ethanol?
cars are 03 z06, 66 327/300 and a 60 with a 350 in it. Might be a stupid question but it can’t hurt to ask.
Old Oct 22, 2021 | 06:59 PM
DLowe's Avatar
DLowe
Find a local airport and buy 100LL. I use 100LL (Low Lead) in my "66 327/350hp car and it runs great. I run it straight at time and also mix it with 90 Octane from a local gas station without any issues. Recently paid $5.20 a gallon, just remember the airport will not let you pump it directly in any vehicle (legally) but you can pump it in a gas can without any legal issues. However 100LL can not be used in modern vehicle with catalytic converters as it will plug them up with the lead in the fuel. A lot of the Octane boost additives out there on most local shelves aren't as them seem and you'll spend a lot of money buying enough of it to obtain the desired Octane. 100LL is a more stable fuel and will provide better Hot (engine) car starts just to name one positive aspect. Good luck
Old Oct 22, 2021 | 07:33 PM
jim lockwood's Avatar
jim lockwood
C2 of Year Finalist (track prepared) 2019
I run all my vehicles, even my fuelies, on Kalifornia's version of E10. I don't like E10 but I can't point to a single problem it's ever caused.
If you car is running fine on your 93 octane E10, I can't think of a reason you should switch to anything else.
Old Oct 22, 2021 | 07:49 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
beside the fact I use PA ethanol laced gas and so does my dad in all his cars with no ill effects I can't see why you need to switch
Old Oct 22, 2021 | 08:22 PM
thoyer's Avatar
thoyer
I run 93 in my Z06 and 89 or 91 in the other cars which all have lower compression then the Z06. I only use TopTier fuel in the cars including my daily drivers. Local Shell station is where I usually go.
On that note, I recently had the carb apart on my 60. First time in probably 10 years - clean as a whistle inside. Based on all of the bad publicity you read on the internet about the ethanol fuels, I was expecting the worst. I was pleasantly surprised.
Tom
Old Oct 22, 2021 | 08:43 PM
AlHewitt's Avatar
AlHewitt
My story about ethanol fuel is different. After buying my 57 (Chevrolet car) with a Rochester FI on it the previous owner had run ethanol fuel in for years. The fuel tank had major rust in it that had worked its way through the fuel delivery system. A major overhaul and replacement of parts from the gas cap to injector nozzles was required. I will never run ethanol gas in my FI cars.
About 100LL avgas, yes I use it from my local airport, it has some good aromatics in it that reduce vapor issues and the shelf life is very good. Acquiringly it can be tricky to acquire as airports have been tasked with insuring that it is used for aviation and not road usage. So, I can access it after hours when the fuel ***** are gone or taxi my airplane to the pumps with 5 gallon cans in the baggage compartment. Either way this gas is great with high octane and good shelf life and no ethanol... Al
Old Oct 22, 2021 | 09:40 PM
R66's Avatar
R66
I use 87 ethanol (10%) in both the 300hp / 327 and the 325hp / 350 with no issues. Maybe I am just lucky.
Old Oct 23, 2021 | 11:02 AM
SWCDuke's Avatar
SWCDuke
The first consideration is you need enough octane to keep the engine out of detonation. For your '03 follow GM's recommendation in the owner's manual. Your '66 327/300 required "premium" when new, but if it was rebuilt with lower compression it may tolerate 87. You have to test, and the same applies to the 350 in the '60.
If the cars are normally kept in an non-condensing humidity environment, like a garage, and you drive them enough to consume at least a full tank of fuel in a year, ethanol will likely not cause problems.
Duke
Old Oct 23, 2021 | 11:05 AM
DLowe's Avatar
DLowe
To each their own, but if your car is not a daily driver and more of a seasonal driven car like a lot of classic cars are then your playing with fire using ethanol fuels. Ethanol absorbs water and that is not good for fuel system in the long run. I'm not saying your lines or tanks will rust out tomorrow but it will eventually cause issues for stored vehicles. I personally like to eliminate problems before they happen instead of being reactive and my choice is non-ethanol for my vehicles, boats, etc that are not driven or used regularly. I recently replace my fuel line fuel line that was rusted out on my 1966 327/350 car and most know that requires removing the body to do it properly and I don't care to do that again.
Old Oct 23, 2021 | 03:52 PM
domenic tallarita's Avatar
domenic tallarita
I use 100 mixed, but if he has a cat converter the 100 will mes it up.
Dom
Old Oct 23, 2021 | 05:33 PM
CorvetteMikeB's Avatar
CorvetteMikeB
Old Oct 23, 2021 | 06:10 PM
1963GrayGray's Avatar
1963GrayGray
2025 C1 of the Year - Unmodified Finalist
2020 Corvette of the Year Finalist (stock)
2019 C1 of Year Winner (stock)
I use 50% ethanol free with 50% 100 octane av gas in my 57 FI car and premium pump gas in my 02 Z06.
This application seems to work well for me.
Old Oct 23, 2021 | 07:57 PM
Saddletan's Avatar
Saddletan
C2 of Year Finalist (appearance mods) 2019
I wouldn’t post this online since it’s been illegal since 1996. Never know who may be watching. Enforcement doesn’t seem widespread, yet.
I run 91 pump gas with my 10.5 compression engine. For my LS 7 I mix 1 gal 100 UNLEADED to 3 gal pump 91. That makes 93. I get the 100 at one of two nearby racetracks. It ain’t cheap but no foul in Kommiefornia.
Old Oct 24, 2021 | 11:31 AM
dmtparker's Avatar
dmtparker
Tom
Had your car sat for any period of time? That is the biggest problem with E10 - it really gums up carbs if allowed to sit (not good for rubber either). I just rebuilt my AFB after it sat with minimal use (but was started monthly) for 2 years. It was terrible. I now add 1 oz of ATF per gallon. Too soon to report results, but others swear by it.
Old Oct 24, 2021 | 12:14 PM
inspectorudy's Avatar
inspectorudy
My retirement hobby is the restoration of old John Deere garden tractors. The biggest problem I have is with the carburetors and Ethanol goo in them. These older tractors sit a lot during the winter months and the Ethanol turns aluminum and rubber into a mess. I drive my car about two or three times a week but during the winter it will be much less. I have seen that my local gas station hasn't had any Ethanol-free fuel for about two weeks. I'm running E-10 now but for the winter months as I tell all of my customers, NEVER store your machine with E-10 in the tank/carb. I will put Ethanol-free in the tank for the winter. E-10 is an ok fuel if it is used daily but for storage or seldom use, it is toxic.
Old Oct 24, 2021 | 02:49 PM
Audiophobe's Avatar
Audiophobe
I'm not trying to bring this thread in a different direction but do the ethanol gas treatments help with these problems?
I always put a couple of ounces in every fill up.
I have no way to guage it helps other than I have had no obvious problems.
Old Oct 24, 2021 | 07:49 PM
thoyer's Avatar
thoyer
The car(s) sit a lot. Maybe they get 200 or so miles put on them a year. The Z06 sometimes more if I take it to Carlisle.
Tom
To Fuel question
Old Oct 26, 2021 | 12:49 PM
jb_va2001's Avatar
jb_va2001
DC Area Events Coordinator
I have 93 octane pure gas ~1 hour from my home. That pure gas plus Avgas (101LL) or Octane Supreme gives me the best results. I avoid using any gas with ethanol, particularly so when fall arrives and sitting a few months over winter becomes likely.
http://www.wildbillscorvette.com/octanesupreme01.htm
Helpful... https://www.pure-gas.org/extensions/maps.jsp
Old Oct 26, 2021 | 02:21 PM
68hemi's Avatar
68hemi
C1 of Year Finalist (performance mods) 2019
Tom
Does anyone use StaBil? If so with what results?
Old Oct 26, 2021 | 02:34 PM
dplotkin's Avatar
dplotkin
2015 C2 of the Year Finalist
I used Stable religiously for 20 years. Never a problem come spring. Then a know-it-all said Stable is Kerosene with some coloring and works by putting an oil slick skin on top of the fuel to prevent it from evaporating. Kind of like the plumber's advice to put a few drops of cooking oil in a the drain of an infrequently used sink.
So that season I skipped it in enlightened protest. That Spring the Impala's 20 year old 4GC needed a go-through and the Corvette was recalcitrant at its first start but fine since.
So I went back to it, but it's probably voodoo or the same reason I still pick up pennies.
Dan
