[C1] Cleaning up interior floor
Old Dec 22, 2021 | 06:33 PM
mmoltisanti's Avatar
mmoltisanti
Default Cleaning up interior floor
Hi all,
Any recommendations on what's best to use to clean up the interior floor of 60+yrs of grime & dried adhesive from the carpet ? Attached image below...
Old Dec 22, 2021 | 07:54 PM
DZVette's Avatar
DZVette
I used 3M Adhesive Remover when I did the '65. I was a real mess of glue and some jute fiber. Spray it on let it sit a bit and then scrape it off. Work in a well ventilated space and perhaps where a respirator if need be. It may take several sprays depending on how thick the glue is. Lots of rags and paper towels also required.
Dave Z
Before
After
Note the incorrect carpet piece that was in the car when we got it. No rear blower panel.
Old Dec 22, 2021 | 08:41 PM
Hermn59's Avatar
Hermn59
I used a scraper, lacquer thinner, Scotch-Brite pads, paper towels, and a lot of elbow grease. Good luck!
Old Dec 22, 2021 | 09:41 PM
How Are You's Avatar
How Are You
These Vettes must cost a fortune to maintain!
Old Dec 22, 2021 | 09:57 PM
Tevroc98's Avatar
Tevroc98
I got an old hand wire brush to start out getting the old jute off. It clogged it up but did remove it pretty well.
Old Dec 22, 2021 | 10:16 PM
mmoltisanti
Dave Z
Before
After
That looks pretty amazing. Thanks for the tips
Old Dec 23, 2021 | 10:32 AM
2KREDVert's Avatar
2KREDVert
The OP has more to worry about than cleaning adhesive, he's got some big holes to fix.
Old Dec 23, 2021 | 11:43 AM
mmoltisanti
THAT came really clean !
Old Dec 23, 2021 | 01:55 PM
Railroadman's Avatar
Railroadman
St. Jude 15 Year Donor
St. Jude Donor '09 thru '26
I used AutoTech "Quick and Easy" and was very pleased with the results. Be sure you have adequate ventilation and a proper mask (for fumes, not just dust).
Old Dec 25, 2021 | 12:00 PM
65air_coupe's Avatar
65air_coupe
Maintaining them is cheap compared to anything new. For instance have you priced a starter for a new car versus an older vette? It's the tinkering and upgrading that can run into some serious money. My 5 speed cost me nearly as much as the car did initially.
To Cleaning up interior floor
