I have a 61 stock with only average mechanically abilities. all dash lights are very dim even at highest setting. (turning the light switch ). It has been this way for a long time. Head, door and tail lights work fine. I would appreciate some ideas of where to start looking.
Great forum , thanks.
I changed to LED dash lights from Superbrightleds.com, and they all work and are much brighter.
Note that my lens and old bulbs were clean, and the difference was "dramatic" when I made the change!
Here is what I posted previously:
I used the Superbrightleds.com # BA9s-WWHP5 (warm white) LEDs on my 62, and am very pleased with the results.
Was surprised at how bright they were, and that I actually "needed" to dim them - never used the dimmer previously).
Don't waste your time, money, and effort on the Ebay LEDs (I did, and regretted it - they were not a "bargain" after all).
Note that on a few of the LED bulbs, I had to add a dab of solder onto the electrical tit of the bulb contact, in order to make it a hair longer. I am sure that the contact spring in the bulb socket had taken a "set" and was not as strong as it was when new +22 years ago, when the wiring was replaced.
Plasticman
Does the cluster have to come out to replace the bulbs?
On my 62, no the cluster does not need to come out to replace the bulbs., but it is a tight fit for my medium size hands.
I had to use a long flat blade screwdriver to seat a few of the bulbs into the gauge cluster (could get the bulbs into the cluster, by hand, but seating them required more force than I could apply with my hand at that angle).
Also should note that I tried the LEDs in the turn signal indicators, and that did NOT work.
And I do have an electronic flasher, so that should not of been the problem. But of all my gauge lights, my turn signal indicators have always been the brightest anyway.
Plasticman
Per this post and others I did the same. I’ve got new wiring and the dollop of solder needs to be added.
Plasticman
That's interesting. I'm just getting ready to order/replace my dash bulbs with LED's and especially the TS bulbs since one burned out. I was told to make sure I ordered the same color LED to match the color of the lens (green/green, red/red) and use the warm white as you did for gauge lighting.
Why did the TS LED's not work for you? I don't need to order bulbs I won't use.
Here what I posted previously in 2016 (had to find my previous posting, since my memory fails sometimes):
Note that I tried one of the Green LEDs in the turn signal indicators, and because I have LEDs in my turn/brake/park bulbs, I have an electronic flasher.
The Green LED slowed the flash rate considerably, so I did not use them. Evidently my electronic flasher "needs" the added current from the small indicator lamp.
If you have a standard (bimetallic) flasher, perhaps the Green turn signal indicator bulbs would work for you.
The other option would of been for me to add a load resistor across each turn signal bulb circuit. In my case, it was not worth the bother, since I have a loud "clacking" circuit that tells me that they are on.
Plasticman
I changed to LED dash lights from Superbrightleds.com, and they all work and are much brighter…
Plasticman
Thank you very much. I have LED parking and taillights so I had to go with the electronic flasher to control them. But, I will stick with the incandescent bulbs for TS if it means having to add resistors for LED usage. I don't drive it at night, so might just stick with incandescent bulbs for all panel lights.
