ignition switch replace
Old Mar 1, 2022 | 07:23 PM
D67's Avatar
D67
Default ignition switch replace
Ordered a new ignition switch and key cylinder from ZIP PRODUCTS for my 67. I learned how to remove the old switch from this forum. Now I am trying to figure out to install the key cylinder into the ignition switch. HELP PLEASE!
Old Mar 1, 2022 | 07:35 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
Stick a paper clip into the small hole
Old Mar 1, 2022 | 07:37 PM
dcamick's Avatar
dcamick
2019 C1 of Year Finalist (appearance mods)
Stick a paper clip into the small hood
Small hole and turn Key Counterclockwise......I think? I've never actually done it.....
https://www.corvetteforum.com/forums...-corvette.html
Old Mar 1, 2022 | 08:48 PM
R66's Avatar
R66
Try putting the key in the new cylinder, then put it in the ignition switch at the accessory position. I think that is how I did it a couple of years ago.
Old Mar 2, 2022 | 09:31 AM
rayL79's Avatar
rayL79
I don't think you need a paper clip to install it (only for removal). Here's the page from the 66 chassis service manual...hope 67 is the same.
Ray
Old Mar 2, 2022 | 11:14 AM
R66's Avatar
R66
Just went out to the garage and verified you DO have to have the key in the cylinder to install it in the switch. You do not have to push in on the brass pin. Line it up with where it was when you removed it from the old switch and lightly hold in and turn it clockwise a bit until it slips in. You might want to compare the old switch with the new as far as grooves for the cylinder to make sure they are the same. I am not sure they didn't change things over the years. Some switches like the 066 were one year only I believe, but that may have just been electrical connections.
Old May 8, 2023 | 01:03 PM
vark_wso's Avatar
vark_wso
posted incorrect response; sorry
To ignition switch replace
