I've watched a couple of videos on how to measure and adjust camber but none of them were C2s. Can someone tell me how to measure and adjust caster on a C2? Is it even possible on these cars? I have a no-return-to-center situation and before I send the steering box off to have it adjusted I want to make sure the caser angle is correct.
To measure caster yourself, you need a caster/camber guage and a set of turn plates. You've seen these gauges, no doubt. They magnetically attach to the front wheel hub. In use, you turn the front wheels 20 degrees one way, re-zero a measurement (going from memory), then return to center and read caster off a bubble level.
However, any alignment shop can measure, report, and adjust caster.
You can measure or at least evaluate camber on a level surface with a level but not caster. As Jim said you can get a camber/caster gage unit for home alignment. Turn plates are nice. A pretty level piece of pavement or floor is necessary. Do you have power or manual steering.
Jim is dead on. I wouldn't reinvent the wheel here. Having owned countless Corvettes for over a 50 yr. period, I can't remember the last time I had to perform an alignment. A good front-end person, when having the car on the rack, can also diag other issues that you might not be aware of.
Dan, you used the phrase "A good front-end person", I might as well look for a unicorn. I had it aligned but the "Old guy" was about 40 years old, claimed he knew old classic cars. He didn't. I'll look around some more but it is getting hard to find anyone who works ao anything that isn't computer driven.
Some of the Chevrolet Dealerships have the service lane, you park it in the square and they laser it, have a print out. They so enjoyed seeing the old Vette, they charged nothing.
While you're looking to determine your caster, I offer a bit of advice from John Z some years ago - with modern radials try to get close to 4 degrees as you can for better drivability. The original spec was more conservative and intended for bias ply tires. And there's a local shop that can do old vettes but the owner injured his should last fall and hasn't called me back yet about doing mine so he may have just quit! He's probably my age or older so it wouldn't surprise me if he's decided to hang it up.
caster is adjusted by adding shims to the rear, or removing from front. caster adjustments will affect camber. i think you can move shims from front to rear to increase caster with minimal affect on camber.
agree you want more caster with radials than OE specs. however i dont know if you can get to 4 with stock unmodified arms. I think I was only able to get to like 3 with mine.
I am sorry to hear that. What did he screw up? Alignment isn't that hard a concept to understand.
Front wheel alignment
Power steering
Camber 0
Caster 2.5 If you can get it to 3 great, but usually about 2.5 is all you can get out of it and it will track very well with 2.5
Toe 1/32 (for total toe of 1/16)
for manual steering go for 1.75 camber. Any more than that and the wheel is to heavy.
You can set it yourself but you need a really level floor. I took two vinyl tiles and put grease in between then to serve as turn plates, it worked great.
Tiger Joe is right about the Caster adjustment. It is conducted by measuring camber with the wheels straight and then turned to 20 degrees (or so) away from the car. I did not use the turn plates Jim mentioned which the friction caused will induce error but for your purpose might be OK, it worked for me. I cut a piece of 1x1 wood to the diameter of the rim and notched the center to clear the wheel bearing cap. I used and angle finder app on my smart phone to measure camber. Then I used the simplified formula to find the caster:
Here is an excerpt from a website for the procedure I used:
1. Turn 20 degrees left of center and take a camber reading.
2. Turn 20 degrees right of center and take a camber reading.
3. Take the difference and multiply by 1.5, that is your castor. i.e. left reading +1, right reading +4. Difference =3 x 1.5 = 4.5 deg positive castor.
I was able to solve my "return to center problem" using this method. There is a more complex formula that uses trigonometry , will be more accurate but since I am using sticks, cell phone and no turn plate I avoided it: https://motoiq.com/wrench-tip-how-to...n-alignment/3/
Even a couple of 12" squares of wax paper on top of each other, under each front tire, can act as a "turn plate"...
Not ideal, but in a pinch...
And I gave up on "alignment shops", for the older cars years ago. They are fine for the most part for newer vehicles, but don't ever get an alignment on anything late on a Friday.
Thank you all for your ideas. I do have electric power steering so turning won't be an issue. I am not trying to align my car myself only to see if the caster is in the ballpark. Right now my car drives very well with zero lash but no return to center. Can someone please explain how removing or adding shims to the upper arm pivot can change the caster? I can see how it would change the camber but I'm lost on it changing the caster.
Adding shims to the rear, and/or subtracting them from the front, of the upper control arm, will rotate the arm a few degrees, moving the upper ball joint rearward, and adding caster. Obviously, doing the inverse with shims will rotate the upper ball joint forward, and reduce caster.
Adding or removing shims equally from the front and rear will adjust camber only.
There are 2 alignment parameters that return your steering to center: steering axis inclination and caster. Steering axis inclination should be enough to return your steering to center even with low caster. Too much friction in the steering system can cause a lack of returnability. I think your electric steering may be adding too much friction...? I would make sure your ball joints are well lubricated too. Tell your alignment technician about the returnability problem.
Live well,
SJW
Doing this will affect camber, which after finding castor, you will want to reshim for your camber.
I too was concerned about the electric power steering being the culprit but unlike hydraulic PS, I can turn it off and there is no effect or drag on the steering system. I have done this on the road and it didn't help the issue. I have planned to send the gearbox to Gary but wanted to be sure that it was the problem before spending big bucks on the box. When I had it aligned last year, the right control arm, front bolt ran out of shimable threads to reach the desired setting. I have '65 disc brakes on the front but that was done when there was no return-to-center already.
