Removal
Old May 2, 2022 | 11:33 AM
maggiesadie8525's Avatar
maggiesadie8525
Default Removal
I have a 66 corvette that is spayed black underneath where it should be natural fiberglass . How do I removal the black spay paint. Any ideals? Thank you
Old May 2, 2022 | 11:50 AM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
Assuming it's lacquer paint, lacquer thinner should remove it. A lot of work and if you use this thinner, be sure to be in a very ventilated place and use eye protection.
Old May 2, 2022 | 12:18 PM
64L76's Avatar
64L76
I used acetone for that job - works great - keep flames away, wear eye protection - you will need plenty of ventilation.
Old May 2, 2022 | 01:40 PM
Vitaminmopar's Avatar
Vitaminmopar
Use citristrip as a primary paint remover, use lacquer thinner or acetone for small clean up detail if necessary. The advantage of citristrip is no objectionable fumes and you are not trying to put a harsh, flammable liquid solvent up over your head. It is safe for fiberglass, scrape or wipe off residue, repeat if necessary, clean up with soap and water or odorless mineral spirits. If paint is a poly or epoxy, residue may turn into a goo that is difficult to remove with soap and water, mineral spirits, lacquer thinner, or acetone. If that happens, using denatured alcohol will work getting the goo off. Whatever you use, wear gloves and eye protection.
Old May 3, 2022 | 07:26 AM
maggiesadie8525
Thank you everyone
Old May 3, 2022 | 09:19 PM
smacota1's Avatar
smacota1
If you use acetone be sure to use gloves. Acetone is accumulative in the body.
Old May 5, 2022 | 12:14 PM
Roger Walling's Avatar
Roger Walling
The title of your post leaves much to be desired.
Even the addition of one word, "paint" would make a great improvement.
Old May 5, 2022 | 01:03 PM
maggiesadie8525
I guess you are mad because you don't have a clue on removing anything. If you read the question, which states paint, needed to be removed. Read the replies you will learn how to Remove paint. Have a good day!
Old May 5, 2022 | 01:46 PM
66jack's Avatar
66jack
If the body is off, what about soda blasting?
Old May 5, 2022 | 04:15 PM
Roger Walling
I have removed more paint in 60 years from vehicles than almost everybody on this site by sanding, razor blades, sandblasting, paint remover, fire, pressure washing, air pressure, and washing with solvent.
The point that I was making what the wording for the title of your post "Removing" that appears in the list of posts that most people use to determine whether to read a post or ignore it.
It was meant to help, not to criticize. I guess that some people just like to be sarcastic to others.
Roger
Old May 5, 2022 | 04:33 PM
ricks327's Avatar
ricks327
Acetylene torch always works for me.
Old May 6, 2022 | 05:30 AM
maggiesadie8525
Point taken. I didn't say removing but removal
To Removal
