Tach problem
Old May 3, 2022 | 08:37 PM
403b's Avatar
403b
Cruising
Default Tach problem
Had to have the tach and Speedo rebuilt. Tach didn’t wk woken Igor the car. After reinstalling the tack with a new bulb the tach is working but the light keeps flashing. Checked connections and the bulb more than once. I’m stumped.
Old May 3, 2022 | 08:50 PM
Vet65te's Avatar
Vet65te
Mike - I'm guessing you're talking about a midyear, not a solid axle? If so, when you said you installed a new tach 'with a new bulb' not sure what you meant? There's a bunch of bulbs attached to the cluster, a bunch of gray wire bulbs are for instrument panel illumination, others are for turn signals and as mentioned, flashing warning lights for the Parking Brake and Headlight Pods. Those last two use a #257 flashing bulb. Any chance that's what you installed into a gray wire panel light socket?
Mike T - Prescott AZ
Old May 7, 2022 | 10:35 PM
403b's Avatar
403b
Cruising
Default Thanks
Just wanted to saw thanks to those who solved my blinking light problem and for the advice on redoing the suppension. I need to replace a bent tie rod and clean it up some other than that it’s going pretty well
To Tach problem
