[C2] steering column
Old May 7, 2022 | 10:06 AM
Dave Witman's Avatar
Dave Witman
Default steering column
I have a 67 late standard column that is missing lower bearing spring seat (262474) and lower bearing washer (7802124) per Jim Shea papers. Does anyone have a parts source for these.
Old May 7, 2022 | 10:40 AM
Factoid's Avatar
Factoid
Here you go:
https://www.zip-corvette.com/63-67-c...omponents.html
Old May 7, 2022 | 10:48 AM
66jack's Avatar
66jack
Might as well change the bearing while your into that deep..
Old May 7, 2022 | 01:05 PM
Dave Witman
ok thanks they have the washer but not seeing the spring seat (262474) for 67 late column. I am replacing bearings.
Old May 7, 2022 | 09:02 PM
Greg Hollowaty's Avatar
Greg Hollowaty
Try calling David Sokolowski he is here on the West Coast (310) 329- 5334. David has lots of C2 parts.
Old May 7, 2022 | 09:13 PM
64L76's Avatar
64L76
Pretty common repro parts - available from most vendors, try Paragon if ZIP is a zero inventory.
Old May 7, 2022 | 10:59 PM
dkleather's Avatar
dkleather
2016 C2 of the Year Finalist
Buy the lower bearing too. It’s probably shot. Zip, Paragon, Corvette Central and others have the repro parts.
To steering column
