SB overheating
You should select an idle speed with the VAC connected and keep readjusting it to that as you change things, like timing or centrifugal advance. Given the B26 VAC you do not want idle speed less than what it takes to pull about 14" vacuum.
You still have to learn the concept of a "spark advance map". So do a lot of others. Read my tuning seminar. Search for threads stated by me.
Duke
I have your tuning seminar and several of your other threads, along with others on this subject but parsing out where I'm at to what I need to do is taking me some time. If I'm at 8* with stable 650 rpms without the VAC and 36*-38* is my WOT target and I'm currently too much too soon, then it follows the springs are my next target. Is this correct?
For your idle behavior 14-15" @ 650 the B26 VAC is ideal.
Remove the cap and rotor, snap a photo of the centrifugal advance mechanism and post.
Duke
Duke
Picture is before I swapped out the B1 for the B26. And you’re correct. I didn’t take it up to all in since I was working alone on this and running out of hands. I’ll try and conscript someone to run the throttle up to the “all in” advance and report.
I looked online at the Mr. Gasket spring kit mentioned a lot here. All the springs in the kit appear to have more windings than the ones on my distributor. I know wire gauge has a lot to do with spring tension as well but it’s lending more evidence to believe that the current springs are too light by comparison. Anyone agree?
Gentlemen again, thank you.
Also I checked all the relevant parts along the coolant path and replaced those that were suspect or flat out fails. In my case, water pump, expansion tank cap, fan clutch and coolant. The radiator is new as are all the hoses. As a matter of course, I replaced the thermostat as well. An IR gun was a great diagnostic tool. It told me, among other things, that the temp sender and dash gauge were inaccurate but within livable limits. It's bloody hot right now in SW FL. I don't drive the car until late October. But I've noticed it can idle in the driveway in the hot sun way longer than it did before before creeping up above 215-220*. So I'm calling it mission accomplished.
With all the parts in the cooling system up to spec, I started in on the timing as, I learned, it is relevant to engine temperature .......and fell down the rabbit hole. I'm trying to find my way out of that on another thread.
Check every part in the cooling chain. Repair or replace those that don't pass muster. If you do all that and you're still overheating, you might need to look at your timing. As a couple guys suggested, there's always the electric fan option if you hit a brick wall. Good luck.
new 180 thermostat, replaced fan with 7 blade and new fan clutch. Even added the AC radiator seals (upper and lower) …. still in traffic temp increase to 230-230 but drops back to 190 once speed increases.
Should it be very obvious when the fan clutch fully engages? I’m not sure it’s working properly.
From what I've Iearned, a quick test for the fan clutch is before you start the car, spin the fan blade and note resistance and rotation. It should spin fairly easy and offer little resistance. Start the engine and let it come up to temperature. If you have a IR gun, this is a good time to check temperatures along the coolant path. Scan your water outlet fitting at the thermostat and/or the sending unit and note that temperature. You'll be able to tell when the stat opens up +/-. Compare that with your dash gauge. Do this several times while running the engine, allowing it to "overheat" into the yellow range on the dash gauge or until you start getting temps higher than you're comfortable on your IR gun. With the driver's window down, reach in and shut it down and watch the fan. If it stops nearly immediately, that's a good sign it's ok. Try to spin it as before. If you meet with greater resistance and less travel than you did when the engine was cold, your fan clutch is ok.
You didn't mention replacing the expansion tank cap. If you can have yours tested that would tell you if it's holding @ 15#. If not, get a new one. Beyond that, it sounds like you've done everything you can in the cooling department and you may need to check your timing data.
Re-read this thread from the beginning. There are excellent posts by guys far more experienced than me on this. I'm only reiterating what they've posted. Good luck.
Most fan clutches are designed to work on cars with a vertical radiator set up. The springs are set to work with this vertical radiator. The Corvette has an angled radiator and the temps end up being lower at the fan clutch so you need a spring with a lower temp to engage properly. These are hard to find. Some of the older fan clutches allowed you to re clock the spring for lower temps but most do not today.
I have not seen any automotive fan clutch with adjustment slots like this diesel application but it might lead us to a better fan clutch solution for our C2 cars.
