Adding Power Steering
Old Jun 29, 2022 | 02:06 PM
Peavey's Avatar
Peavey
Default Adding Power Steering
I plan to add power steering to my 67 L75 roadster and I want to use an original style power steering unit. (I know that there are aftermarket kits and conversions that are superior to the OEM power steering, but since the rest of the car is true stock I want to keep the car as close to how it "could have come" from the factory.)
I have the ram setup and valve, plus the correct steering box, but I am going to need to source a pump and the brackets. Can anyone tell me if the pumps and brackets were unique to the Corvette or if they used the same parts on other small block equipped cars from the 60's?
Old Jun 29, 2022 | 02:52 PM
Bluestripe67's Avatar
Bluestripe67
Active Streak: 90 Days
We need clarification! First, I don't know of other applications, there could be. Second, No L-75 in '67. that designation was used in previous years when the base motor was a 250HP and the L-75 was the first optional one on the list at 300HP. So, what engine is in your car? Assuming it is a 327/300HP, the PS brackets are sold in kit form along with the correct pump from most vendors. You will also need to get the correct pulley for the crank. Dennis
Old Jun 29, 2022 | 05:11 PM
JF in MI's Avatar
JF in MI
Pro Mechanic
2023 C1 of the Year Finalist - Modified
This may help
https://www.corvetteforum.com/forums...or-a-66-a.html
Old Jul 9, 2023 | 08:05 PM
moonframer's Avatar
moonframer
Thanks for the information
Old Jul 9, 2023 | 09:02 PM
Tom Austin's Avatar
Tom Austin
I installed PS on my '66 a few years ago and sourced the pump from Rock Auto. Good luck with your project!
Tom
Old Jul 9, 2023 | 10:12 PM
65 Pro Vette's Avatar
65 Pro Vette
C2 of Year Finalist (appearance mods) 2019
You should not have to change the steering box all is you need to do is change the Pitman arm off the steering box. The power steering installation is pretty simple.
Old Jul 10, 2023 | 08:25 AM
Tampa Jerry's Avatar
Tampa Jerry
If not already done so, you must move the tie rods to the front hole on the spindle assembly. Jerry
Old Jul 10, 2023 | 09:19 AM
moonframer's Avatar
moonframer
To Adding Power Steering
